StarTech.com DP 2.1 Cable
Quicklinx: HVMBWS00 Mfr#: DP21-10F-DP40-CABLE
£24.62 ex VAT
£29.54 inc VAT
StarTech.com's 10ft (3m) DisplayPort 2.1 Cable is a high-performance connection solution designed to meet the needs of demanding multimedia enthusiasts. With its support for UHBR10, HDR, MST, DSC 1.2a, and HDCP 2.2, this cable can deliver 8K at 60Hz and 4K at 120Hz video resolutions, ensuring breathtaking image clarity and fluidity for gaming, streaming, and professional applications. The cable features a robust construction with a 10,000 insertions lifespan, 600 bend lifespan, and strain relief, making it both durable and reliable. It also supports up to 32 audio channels for a rich audio experience. The inclusion of EMI protection and compatibility with both FreeSync and G-Sync technologies enhances its performance, providing users with a smooth viewing experience. Made from halogen-free materials and featuring a nickel-plated connector, this DisplayPort cable is an environmentally friendly choice that does not compromise on quality or performance.
  • Enhanced Durability
    Designed for longevity, this DisplayPort 2.1 cable has a 10,000 insertions lifespan and a 600 bend lifespan, complemented by a robust ABS housing and strain relief for added durability.
  • High Performance
    Experience high visual quality with support for 8K at 60Hz, 4K at 120Hz, and HDR10, alongside a high data transfer rate of up to 40 Gbps, ensuring smooth, high-resolution video playback.
  • Advanced Audio-Visual Features
    With 32 audio channels, DisplayPort Multi-Stream Transport (MST), EMI protection, and compatibility with both FreeSync and G-Sync, this cable is engineered to deliver a comprehensive multimedia experience.
  • Eco-Friendly Design
    Committed to environmental sustainability, the cable is halogen-free, minimizing the ecological footprint while providing a safe, high-quality connection for all your devices.
StarTech.com 10ft (3m) DisplayPort 2.1 Cable, DP40 DisplayPort Cable w/UHBR10/HDR/MST/DSC 1.2a/HDCP 2.2, 8K 60Hz, 4K 120Hz, DP 2.1 Cable M/M - DisplayPort cable - DisplayPort to DisplayPort - 3 m
DisplayPort cable
Shielded
Passive cable, 8K60Hz support, 4K144Hz support, 1440p support 240Hz, up to 40 Gbps data transfer rate, UHBR10, HDR support, strain relief, EMI protection, halogen free, copper conductors, DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, ABS housing, G-Sync support, FreeSync support, Variable Refresh Rate (VRR), 600 bend lifespan, 10000 insertions lifespan
Length
3 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 2.1
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30
Plated Connector
Nickel
Length
3 m
Outside Diameter
8.2 mm
Connector
DisplayPort 2.1, RoHS, WEEE, VW-1, HDCP 2.2, DSC 1.2a, VESA DP40
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
3 cm
Shipping Weight
325 g
HVMB StarTech.com USB C to DP Adapter - 8K/4K In Stock £15.05
