StarTech.com DP 1.4 Extension Cable
Quicklinx: J1M9WS00 Mfr#: 10F-DP14-EXTEND-CBL
Length: 3m
16 In Stock
£28.65 ex VAT
£34.38 inc VAT
The 10ft (3m) DisplayPort 1.4 Extension Cable by StarTech.com is designed for seamless connectivity and performance. This extension cable features robust 20 pin male and female DisplayPort connectors, ensuring reliable data transfer for high-resolution displays. With support for resolutions up to 8K and a data rate of 32.4 Gbps, it meets the demands of both home and professional environments. Crafted with quality in mind, the cable incorporates shielding using aluminum mylar foil along with braid, reducing interference and maintaining signal integrity. The halogen-free construction and thermoplastic elastomer (TPE) jacket contribute to durability and safety, making it a great choice for a variety of applications. DisplayPort Multi-Stream Transport (MST) support further enhances its versatility, enabling multiple displays to be connected through a single port.
  • High-performance data transfer
    The cable provides a 32.4 Gbps data rate, ensuring high-speed connectivity for a smooth display experience.
  • Superior resolution support
    With support for up to 8K resolution, this cable delivers image clarity for demanding visual applications.
  • Robust shielding technology
    Constructed with aluminum mylar foil and braid, the cable minimizes signal interference, promoting reliable performance.
  • Durable and safe materials
    The halogen-free jacket and thermoplastic elastomer (TPE) material offer durability while ensuring a safer user environment.
  • Flexible connectivity options
    With bidirectional capability and DisplayPort Multi-Stream Transport (MST) support, this cable easily connects multiple displays through a single port.
StarTech.com 10ft (3m) DisplayPort 1.4 Extension Cable, DP 1.4, 8K 60Hz - DisplayPort extension cable - DisplayPort to DisplayPort - 3 m
8K support, bi-directional, halogen-free, passive cable, 32 audio channels, 32.4 Gbps data rate, DisplayPort Multi-Stream Transport (MST), HBR2 support
Length
3 m
Connector
20 pin DisplayPort - male
Connector (Second End)
20 pin DisplayPort - female
DisplayPort 1.4
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
30
Plated Connector
Gold
Length
3 m
Outside Diameter
8.4 mm
240 g
Connector
DisplayPort 1.4, DisplayPort 1.2, DisplayPort 1.4, RoHS, VW-1
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
246 g
Length: 3m
