StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA
Quicklinx: FLYWWS00 Mfr#: SSPMSVESA
Device Type: Docking Station
Type: Docking Station Mount
Device Screen Size: [N/A]
Colour: Black
£14.66 ex VAT
£17.59 inc VAT
Create a clutter-free workspace by mounting your docking station or hub, freeing up space on your desktop. This VESA compatible docking station mount makes it easy to attach a compatible StarTech.com dock or hub to the backside of your monitor.
The docking station mounting plate attaches easily to monitors with a 75x75 or 100x100 mm VESA hole pattern.
Made in Canada, the sturdy and durable dock and hub mount is engineered from 10 gauge steel (3.3 mm thick).
The VESA docking station and hub mount works with monitors mounted on a stand, or attached to a monitor arm. The docking station mount provides a great way to free up desk space in offices in business or commercial spaces. It's also ideal for space-constrained areas, including hot desks and shared workstations, cubicles, mobile and wall-mounted workstations, and home offices.
This innovative mount is designed to work exclusively with compatible StarTech.com products including: Dual 4K Universal Docking Station - USB-C / USB 3.0 - 100W PD (DK30C2DPEP); Dual 4K Universal Docking Station - USB-C / USB 3.0 - 100W PD (DK30C2DPEPUE); Dual 4K Universal Docking Station - USB-C / USB 3.0 - 60W PD (DK30C2DPPD); Dual 4K Universal Docking Station - USB-C / USB 3.0 - 60W PD (DK30C2DPPDUE); Thunderbolt 3 Dock with USB-C Laptop Compatibility (TB3CDK2DP); Thunderbolt 3 Dock with USB-C Laptop Compatibility (TB3CDK2DPUE); 4-Port USB-C 10Gbps Hub - USB 3.1 to 3x USB-A + 1x USB-C (HB31C3A1CS); 4-Port USB-C 10Gbps Hub - USB 3.1 to 4x USB-A - Self Powered (HB31C4AS); 3-Port USB-C Hub with GbE - USB 3.1 (10Gbps) (HB31C2A1CGS) .
Using the docking station mounting kit, complete with mounting plate and screws, you can mount your compatible dock or hub to the back of your monitor that is recessed up to 7mm. When installed, the dock mount sits almost flush with the monitor, while still allowing easy access.
StarTech.com Docking Station Mount - VESA - Back-of-Monitor Mounting Plate - mounting plate - TAA Compliant
Mounting plate
Placing / Mounting
On-the-monitor mountable
Package Content
4 M4 x 12mm screws, 4 plastic spacers, 4 M3-0.5 x 5 mm countersunk screws, 4 M4 x 20mm screws
Product Material
10 gauge steel
12 cm x 21.35 cm x 0.32 cm
500 g
VESA 75x75, VESA 100x100
TAA Compliant
5-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, HB31C2A1CGS, HB31C3A1CS, HB31C4AS, TB3CDK2DP, TB3CDK2DPUE
Mounting plate
Placing / Mounting
Product Material
10 gauge steel
Package Content
12 cm
21.35 cm
0.32 cm
500 g
14.5 cm x 29 cm x 1.2 cm / 540 g
RoHS, REACH
TAA Compliant
Limited warranty: - 5 years
FLYW StarTech.com Adjustable CPU Wall Mount In Stock £33.33
FLYW StarTech.com Thin Client Mount - VESA In Stock £23.04
FLYW StarTech.com 3 Port USB C 3.1 Gen 2 Hub with Ethernet Adapter In Stock £63.26
FLYW StarTech.com 4-Port USB C Hub USB 3.1 Gen 2 (10Gbps) 3x USB-A & 1x USB-C In Stock £59.54
FLYW StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla In Stock £9.29
FLYW StarTech.com TV Accessory Mount - Universal - Media Player/Apple TV In Stock £27.42
FLYW StarTech.com PC Wall Mount Bracket/Holder In Stock £60.24
FLYW StarTech.com Computer Tower Cart, Rolling In Stock £31.64
FLYW StarTech.com VESA Mounting Bracket In Stock £7.75
Colour: Black
