StarTech.com Dock for USB-C Laptops 2x DVI
Quicklinx: CNDJWS00 Mfr#: DK30BACDD
Expand your USB Type-C equipped laptop into a powerful office workstation, using a single USB 3.0 cable. This DVI dual-monitor docking station for laptops easily connects to your USB-C equipped laptop, letting you create a full-size workstation that delivers display flexibility, fast charging, and desktop convenience to your home or office workspace.
It's a vital laptop accessory for virtually any USB Type-C equipped laptop, such as the Dell XPS 15, 13, or 12, as well as the Google Chromebook.
USB-C is the next generation of universal connectivity, and the connectors are small, reversible, and easy-to-use. Most new laptops feature a USB-C or Thunderbolt 3 USB-C port, but they often lack other vital connectivity ports.
This dock adapts to your USB-C equipped laptop to deliver a variety of useful connectivity ports, including dual-DVI video output, five USB 3.0 ports, Gigabit Ethernet, and a headset jack.
Boost your productivity and add dual-monitor support to your workstation. With dual video, you can work faster by viewing more content at a glance and avoid the nuisance of rearranging or resizing multiple windows.
For extra display flexibility, we've included two DVI video adapters, so you can avoid the frustration and costs of purchasing additional products just to fit the displays you already use.
Now, you can leave the stress of interface limitations at the door by adapting to the most popular monitor types, right out of the box. With a range of video output options, the dock is ideal for hoteling or hot desking.
Charge your mobile devices faster, with or without a laptop connected to the dock. USB charging is convenient, fast, and accessible through two always-on USB fast-charge ports on the front of the dock. You can simultaneously maintain work efficiency, while adding charge-and-sync flexibility for up to two mobile devices (two tablets, or one tablet and one smartphone).
Now, you can easily fast-charge your devices and connect numerous USB peripherals through the integrated 5-port USB 3.0 controller. Perfect for external USB 3.0 hard drives, the docking station supports UASP-enhanced performance for faster data transfer rates, which means less waiting and more productivity.
With a single connection to your laptop or Ultrabook, your required peripherals remain constantly connected. You can overcome laptop port limitations and reduce the hassle of constantly reconnecting devices (such as your wired Gigabit Ethernet connection), to create an organized and full-sized workstation with less clutter.
For greater host compatibility, you can also use the docking station with laptops that feature the more traditional USB 3.0 (USB-A) port, making it perfect for organizations that have a mix of different laptop makes and models. With the included cable and USB-C adapter, you can connect the dock to virtually any laptop, regardless of the laptop's host USB port type.
Plus, for a clean and customized workspace you can position the docking station horizontally or vertically (tower), using the optional dock stand that's included.
StarTech.com USB Dock - USB-C to USB-A Adapter - Compatible with Windows - Dual Monitors - HDMI and VGA Adapters - DK30BACDD - docking station - USB - DVI - 1GbE
Docking station
Docking Interface
USB
Video Interfaces
DVI
2.3 cm x 17.8 cm x 8.3 cm
285 g
Black & silver
Japan, North America, United Kingdom, Europe
Gigabit Ethernet
Power adapter AC 120/230 V
3-year warranty
Docking station
2.3 cm
17.8 cm
8.3 cm
285 g
Enclosure Colour
Black & silver
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0, USB 3.1
1 x display / video - DVI-Digital (dual link) - 24+1 pin digital DVI , 1 x display / video - DVI-Analog/Digital (dual link) - 24+5 pin combined DVI , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 5 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 1 x audio - mini-phone 3.5 mm 4-pole
1 x USB-C cable - external , 1 x HDMI-DVI adapter - external , 1 x DVI-I to VGA adapter - external , 1 x SuperSpeed USB cable - external - 1 m
4 x rubber feet, stand, 2 x stand screws, screwdriver
LED indicator, DisplayLink DL-3900 chipset, UASP transfer protocol, full duplex support
FCC, RoHS
Power adapter
AC 120/230 V
Microsoft Windows XP (32-bit) SP3, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
Limited warranty - 3 years
50 °C
CNDJ StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £57.25
CNDJ StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort In Stock £84.14
CNDJ StarTech.com Triple-Video Laptop Dock In Stock £91.54
