StarTech.com DisplayPort VGA HDMI Converter Switch
Quicklinx: C7CPWS00 Mfr#: HDVGADP2HD
Hurry, only 1 left in stock!
£267.59 ex VAT
£321.10 inc VAT
Switch between DisplayPort, VGA or two HDMI source devices on one display, with automatic and priority switching. This multi-input converter switch lets you connect your DisplayPort (DP), HDMI and VGA audio/video sources to one HDMI display or projector. The switch enables you to automatically or manually switch between your video sources and features built-in signal conversion, which eliminates the cost and hassle of using additional adapters for the sake of compatibility.
This versatile A/V switch supports video resolutions up to 1920x1200 (1080p) on your VGA source and up to 4K at 30 Hz on your DisplayPort and HDMI video sources. For a tidy, professional installation, the converter switch includes mounting hardware.
The A/V switch features built-in HDMI conversion, so you can connect two HDMI sources as well as a VGA and a DisplayPort video source to the same HDMI display, without having to use additional adapters or scalers.
The converter switch ensures hassle-free operation, with two different auto-switching modes: auto-detect switching, which detects and selects a newly connected device, or priority selection, which lets you choose which port should be activated by default for automatic switching. The converter switch is perfect for digital signage applications where an automatic switch can replace a failed source with a secondary input to avoid embarrassing video outages.
This versatile A/V switch has been designed with the boardroom and classroom in mind, with HDMI, VGA and DisplayPort inputs to support a wide range of devices, and a built-in converter that makes it easy to connect to the room's display without having to connect additional adapters. Plus, automatic switching encourages on-the-fly collaboration among students or co-workers, by making it so easy to share a projector or other display device between multiple sources.
The video switch maintains Ultra HD 4K picture quality while switching between content from HDMI and DisplayPort source devices, including Blu-ray players and DVD players, computer systems, video game consoles, digital cable and satellite boxes and A/V receivers.
4K video support ensures a higher level of image clarity and visibility, delivering four times the resolution of 1080p - 8.29 million pixels versus 2.07 million pixels. It offers a more engaging visual experience for audiences in a wide range of venues, including conference centers, boardrooms, educational facilities, and commercial settings.
When connecting a VGA source, the switch supports high-definition resolutions up to 1920 x 1200. With its exceptional resolution and image quality, this switch is ideal for bringing your digital signage to life.
StarTech.com Multi-Input to HDMI Converter Switch - DisplayPort, VGA and Dual-HDMI to HDMI Switch - Priority and Automatic Switch - 4K (HDVGADP2HD) - video/audio switch
Video/audio switch
Subtype
HDMI / DisplayPort / VGA
4K resolution support, 1080p resolution support
AC 120/230 V
200 g
P/N: BOX4CABLE
Video/audio switch
Enclosure Type
Desktop
Subtype
1 x VGA input , 2 x HDMI input , 1 x DisplayPort input , 1 x HDMI output , 1 x audio input
External power adapter
AC 120/230 V
Wireless remote control, mounting brackets, mounting screws
FCC, RoHS
200 g
P/N: BOX4CABLE
C7CP StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £9.37
C7CP StarTech.com High Resolution VGA to Composite (RCA) or S-Video Converter - PC to TV In Stock £95.65
C7CP StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k In Stock £14.12
C7CP StarTech.com Composite and S-Video to HDMI Converter with Audio In Stock £122.65
C7CP StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200 In Stock £90.94
C7CP StarTech.com Conference Table Connectivity Box – HDMI / VGA / Mini DisplayPort to HDMI Output In Stock £208.11
C7CP StarTech.com 2x1 HDMI VGA to HDMI Converter In Stock £128.61
C7CP StarTech.com VGA to HDMI Scaler - 1920x1200 In Stock £207.80
C7CP StarTech.com 6ft DP Mini DP HDMI to HDMI In Stock £94.16
C7CP StarTech.com DisplayPort VGA HDMI Converter Switch In Stock £267.59
C7CP StarTech.com 1080p VGA to RCA and S-Video Converter - USB Powered In Stock £44.36
C7CP StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.26
