StarTech.com DisplayPort/USB 3.0 KVM Cable
Quicklinx: J4LBWS00 Mfr#: DU12210-KVM-CABLE
10 In Stock
£23.52 ex VAT
£28.22 inc VAT
KVM cable provides a reliable connection between a computer and a DisplayPort KVM switch with USB 5Gbps support. Simplify cable management by combining multiple connections into a single bundle. This minimizes the number of individual cables that need to be handled, making installation faster and more efficient. They are perfect for environments where KVMs are essential, such as data centers, server rooms, edge networking, and remote management setups, helping to reduce cable clutter and maintain an organized workspace. This KVM cable works with any operating system, including Windows, macOS, ChromeOS, and Linux. It also supports all major hardware platforms, such as Intel, AMD, and Apple Silicon. KVM combo cable is DisplayPort 1.2 compliant, supporting resolutions up to 4K at 60Hz, HDR10, and DisplayPort audio for high-quality audio/video experience. The USB 3.0 Type-A to Type-B connector provides fast data transfer speeds of up to 5Gbps.
  • Manage Cables with Ease
  • Works with Any KVM Switch
StarTech.com 10ft (3m) DisplayPort and USB 5Gbps KVM Cable - keyboard / video / mouse (KVM) cable - 3 m
Keyboard / video / mouse (KVM) cable
4K60Hz support, HDR10 support, up to 5Gbps data rate
Length
3 m
Connectors
20 pin DisplayPort - male , 9 pin USB Type A - male
Connectors (Second End)
20 pin DisplayPort - male , 9 pin USB Type B - male
USB 3.2 Gen 1 / DisplayPort 1.2
Jacket Material
Thermoplastic elastomer (TPE)
Plated Connector
Nickel
Length
3 m
450 g
Connectors
USB 3.2 Gen 1 / DisplayPort 1.2, RoHS
Shipping Width
39.5 cm
Shipping Depth
13.8 cm
Shipping Height
5.1 cm
Shipping Weight
450 g
J4LB StarTech.com 4-Port DisplayPort KVM Switch With Built-in USB 3.0 Hub - Rack-Mountable In Stock £342.46
J4LB StarTech.com 2 Pt DisplayPort KVM In Stock £287.20
J4LB StarTech.com 2-Port DP KVM Switch, 8K 60Hz In Stock £297.72
J4LB StarTech.com 4-Port DP KVM Switch, 8K 60Hz In Stock £369.44
J4LB StarTech.com 4-Port DisplayPort KVM Switch In Stock £351.85
J4LB StarTech.com Dual-DP/USB 5Gbps KVM Cable In Stock £23.85
J4LB StarTech.com HDMI/USB 3.0 KVM Cable In Stock £21.69
J4LB StarTech.com HDMI/USB 3.0 KVM Cable In Stock £13.41
