The DP2VGA2 DisplayPort VGA Adapter Cable offers a cost-effective DisplayPort to VGA connection, letting you connect a VGA computer monitor to a DisplayPort video card/output, saving the expense of upgrading the monitor for compatibility.
Supporting PC resolutions of up to 1920x1200 and HDTV resolutions up to 1080p, this high-quality adapter offers crystal clear picture clarity. This simple Plug and Play adapter features a pure hardware design with an integrated chip to provide an active digital to analog conversion so that no software or drivers are required. Simply connect the adapter to your DisplayPort video source, and plug your VGA cable into your monitor.
StarTech.com offers a full selection of DisplayPort and Mini DisplayPort adapters and cables making the technology easy to use with your new DisplayPort equipped PC or Mac.
- StarTech.com DisplayPort To VGA Video Adapter Converter - Active - 1080p - DP to VGA Converter (DP2VGA2) - display adapter - 27.94 cm
- Display adapter
- Latched
- Length
- 27.94 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- HD-15 (VGA) - female
- FCC, RoHS
- Black
- 3-year warranty
- Designed For
- P/N: DK30C2DAGPD, MST14DP123DP, MST30C2DPPD, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, TB32DP14, TB32DP2T, TB3CDK2DP, TB3CDK2DPUE, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPM2, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB3DKM2DP, TB3DKM2DPL, TB3DOCK2DPPD, TB3DOCK2DPPU
- Display adapter
- Latched
- Length
- 27.94 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS
- 3-year warranty
- Designed For
StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M | In Stock | £5.80 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £22.36 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £16.07 |
StarTech.com 6 ft DisplayPort to VGA Cable - M/M | In Stock | £32.38 |
StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £18.38 |
StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £20.07 |
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £22.04 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £15.24 |
StarTech.com DP to VGA Adapter with Audio | In Stock | £18.03 |
