StarTech.com DisplayPort to VGA Video Adapter Converter
Quicklinx: 76LQWS00 Mfr#: DP2VGA2
£17.10 ex VAT
£20.52 inc VAT
The DP2VGA2 DisplayPort VGA Adapter Cable offers a cost-effective DisplayPort to VGA connection, letting you connect a VGA computer monitor to a DisplayPort video card/output, saving the expense of upgrading the monitor for compatibility.
Supporting PC resolutions of up to 1920x1200 and HDTV resolutions up to 1080p, this high-quality adapter offers crystal clear picture clarity. This simple Plug and Play adapter features a pure hardware design with an integrated chip to provide an active digital to analog conversion so that no software or drivers are required. Simply connect the adapter to your DisplayPort video source, and plug your VGA cable into your monitor.
StarTech.com offers a full selection of DisplayPort and Mini DisplayPort adapters and cables making the technology easy to use with your new DisplayPort equipped PC or Mac.
  • Reliable connectivity
    The adapter includes a latched 20 pin DisplayPort connector, ensuring a secure connection between the source device and the adapter to prevent accidental disconnection.
  • Optimized video quality
    With support for resolutions up to 1080p, this adapter ensures that video output maintains clarity for presentations and media playback.
  • Active signal conversion
    This active adapter efficiently converts DisplayPort signals to VGA, facilitating smooth compatibility between modern devices and older VGA displays.
  • Compliance with standards
    The adapter is designed in accordance with FCC and RoHS standards, ensuring both safety and environmental responsibility.
StarTech.com DisplayPort To VGA Video Adapter Converter - Active - 1080p - DP to VGA Converter (DP2VGA2) - display adapter - 27.94 cm
Display adapter
Latched
Length
27.94 cm
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - female
FCC, RoHS
3-year warranty
P/N: DK30C2DAGPD, MST14DP123DP, MST30C2DPPD, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, TB32DP14, TB32DP2T, TB3CDK2DP, TB3CDK2DPUE, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPM2, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, TB3DKM2DP, TB3DKM2DPL, TB3DOCK2DPPD, TB3DOCK2DPPU
Display adapter
Latched
Length
27.94 cm
Connector
20 pin DisplayPort - male
15 pin HD D-Sub (HD-15) - female
FCC, RoHS
3-year warranty
76LQ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £20.94
76LQ StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.10
76LQ StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £11.84
76LQ StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black In Stock £18.80
76LQ StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £17.11
76LQ StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.06
76LQ StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.12
76LQ StarTech.com DP to VGA Adapter with Audio In Stock £6.80
76LQ StarTech.com mDP to Dual-Link DVI Adapter In Stock £77.60
76LQ StarTech.com DisplayPort to VGA Adapter - 1920x1200 In Stock £63.42
