The StarTech.com DP2VGA DisplayPort to VGA adapter lets you connect a VGA computer monitor to a DisplayPort video card or other DisplayPort source, eliminating the expense of upgrading the monitor for compatibility. The DP to VGA adapter uses an integrated chip to provide an active digital to analog conversion.
- StarTech.com DisplayPort to VGA Adapter - 1920x1200 - Active DP to VGA Video Converter - Plug and Play DP to VGA Connector (DP2VGA) - display adapter - 25 cm
- Display adapter
- Latched
- Length
- 25 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- HD-15 (VGA) - female
- FCC
- 3-year warranty
- Designed For
- P/N: DK30C2DAGPD, DPPNLFM3, DPPNLFM3PW, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SP123DP, SV231DPU, TB32DP14, TB32DP2T, TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
- Display adapter
- Latched
- Length
- 25 cm
- Connector
- 20 pin DisplayPort - male
- 15 pin HD D-Sub (HD-15) - female
- FCC
- 3-year warranty
- Designed For
|  | StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £20.93 |
|  | StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.17 |
|  | StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £16.80 |
|  | StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £17.11 |
|  | StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £19.06 |
|  | StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £20.32 |
|  | StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £15.11 |
|  | StarTech.com DP to VGA Adapter with Audio | In Stock | £9.11 |
|  | StarTech.com DisplayPort to VGA Adapter - 1920x1200 | In Stock | £62.44 |
