StarTech.com DisplayPort to VGA Adapter - 1920x1200
Quicklinx: FKDQWS00 Mfr#: DP2VGA3X5
Length: 10cm
£64.85 ex VAT
£77.82 inc VAT
This 5 pack of DisplayPort to VGA adapters lets you connect your DisplayPort equipped computer to a VGA monitor or projector and provides you with an efficient, multi-pack option.
Designed for easy deployment, this bulk-pack of DP 1.2 adapters delivers an economical and efficient solution, making it ideal for schools, offices and other environments requiring multiple implementations.
The DisplayPort video adapter makes your DP computer fully compatible with legacy VGA monitors or projectors, eliminating the expense of upgrading to DP displays.
With support for video resolutions up to 1920x1200 or 1080p, you'll be surprised at the picture quality the adapter provides, even when connected to an older VGA monitor, projector or television. The adapter harnesses the video capabilities built into your DisplayPort connection to deliver every detail in stunning high-definition.
This DisplayPort (male) to VGA (female) dongle maximizes portability with a compact, lightweight design, making it the perfect travel accessory to carry with your DisplayPort devices. The ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office, delivering HD video presentations on-the-go or even staying connected at home.
For added convenience, this DP to VGA converter supports plug-and-play connectivity and requires no additional software or drivers for a hassle-free setup.
  • Maximize Efficiency
    Designed for easy deployment, this bulk-pack of DP 1.2 adapters delivers an economical and efficient solution, making it ideal for schools, offices and other environments requiring multiple implementations. The DisplayPort video adapter makes your DP computer fully compatible with legacy VGA monitors or projectors, eliminating the expense of upgrading to DP displays.
  • Crystal-Clear Picture Quality
  • Designed for Ultimate Portability
    This DisplayPort (male) to VGA (female) dongle maximizes portability with a compact, lightweight design, making it the perfect travel accessory to carry with your DisplayPort devices. The ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office, delivering HD video presentations on-the-go or even staying connected at home. For added convenience, this DP to VGA converter supports plug-and-play connectivity and requires no additional software or drivers for a hassle-free setup. DP2VGA3X5 is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com 5-Pack DisplayPort to VGA Adapter, DisplayPort 1.2 HBR2 to VGA Active Adapter, Digital DP to Analog VGA Video Converter Dongle, DisplayPort Male to VGA Female Monitor Adapter - Active DP 1.2 to VGA (DP2VGA3X5) - video adapter - DisplayPort to HD-15 (VGA) - 10 cm
Video adapter
Packaged Quantity
5 (specifications are for single item)
1080p support, active adapter
Length
10 cm
Connector
20 pin DisplayPort - male (input)
Connector (Second End)
15 pin HD D-Sub (HD-15) - female (output)
DisplayPort 1.2
3-year warranty
Packaged Quantity
Video adapter
Length
10 cm
Connector
DisplayPort 1.2, FCC, RoHS, REACH
3-year warranty
Length: 10cm
