StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F
Quicklinx: 67CKWS00 Mfr#: DP2HDMIADAP
47 In Stock
£10.81 ex VAT
£12.97 inc VAT
The DP2HDMIADAP DisplayPort to HDMI Adapter provides a DisplayPort male and HDMI female connector, allowing you to keep your existing (HDMI) display while using a DisplayPort video card/source.
Supporting display resolutions of up to 1920 x 1200(computer)/1080p(HDTV), this cost-effective solution maintains the incredible graphical performance offered by DisplayPort, while eliminating the cost of having to upgrade your HDMI capable display to a display with built-in DisplayPort support.
DP2HDMIADAP is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Backed by a StarTech.com 1 year warranty and free lifetime technical support.
StarTech Advantage
  • Simple, small form factor converter makes a DisplayPort video card backward compatible with your HDMI display
  • Easy to use, no software or drivers required
  • Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p
  • Easy to use adapter, no software required
Applications
  • The DisplayPort to HDMI adapter allows for an easy and hassle free connection to any HDMI display
  • Versatile connectivity
    This adapter features a 20 pin DisplayPort male connector and a 19 pin HDMI Type-A female connector, allowing connection between various devices.
  • High-resolution support
    Delivers video output at resolutions of up to 1920 x 1200, ensuring clarity and detail for various viewing needs.
StarTech.com DisplayPort to HDMI Adapter – 1920x1200 – DP (M) to HDMI (F) Converter for Your Computer Monitor or Display (DP2HDMIADAP) - adapter - DisplayPort / HDMI
Cable
Adapter - DisplayPort / HDMI
Connector
DisplayPort - male
Connector (Second End)
HDMI - female
3-year warranty
P/N: DPPNLFM3, DPPNLFM3PW
Cable Type
Adapter
Interface Supported
DisplayPort / HDMI
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - female
Limited warranty - 3 years
67CK StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
67CK StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £11.80
67CK StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £10.81
67CK StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £9.22
67CK StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £14.95
67CK StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £8.38
67CK StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £63.76
67CK StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
67CK StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.78
67CK StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £21.80
67CK StarTech.com 3ft DP to HDMI cable - 4K In Stock £13.67
67CK StarTech.com 6 ft DP to HDMI cable - 4K In Stock £15.82
67CK StarTech.com DisplayPort to HDMI - 4K In Stock £13.26
67CK StarTech.com HDMI to DisplayPort Converter - 4K In Stock £36.91
67CK StarTech.com 5m DisplayPort to HDMI Cable - 4K In Stock £20.76
67CK StarTech.com 3m DisplayPort to HDMI Cable - 4K In Stock £18.39
67CK StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £21.76
