The DP2HDMIADAP DisplayPort to HDMI Adapter provides a DisplayPort male and HDMI female connector, allowing you to keep your existing (HDMI) display while using a DisplayPort video card/source.
Supporting display resolutions of up to 1920 x 1200(computer)/1080p(HDTV), this cost-effective solution maintains the incredible graphical performance offered by DisplayPort, while eliminating the cost of having to upgrade your HDMI capable display to a display with built-in DisplayPort support.
DP2HDMIADAP is a passive adapter cable that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
Backed by a StarTech.com 1 year warranty and free lifetime technical support.
StarTech Advantage
- Simple, small form factor converter makes a DisplayPort video card backward compatible with your HDMI display
- Easy to use, no software or drivers required
- Supports PC resolutions up to 1920x1200 and HDTV resolutions up to 1080p
- Easy to use adapter, no software required
Applications
- The DisplayPort to HDMI adapter allows for an easy and hassle free connection to any HDMI display
Versatile connectivity
This adapter features a 20 pin DisplayPort male connector and a 19 pin HDMI Type-A female connector, allowing connection between various devices. -
High-resolution support
Delivers video output at resolutions of up to 1920 x 1200, ensuring clarity and detail for various viewing needs.
- StarTech.com DisplayPort to HDMI Adapter – 1920x1200 – DP (M) to HDMI (F) Converter for Your Computer Monitor or Display (DP2HDMIADAP) - adapter - DisplayPort / HDMI
- Cable
- Adapter - DisplayPort / HDMI
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - female
- 3-year warranty
- Designed For
- P/N: DPPNLFM3, DPPNLFM3PW
- Cable Type
- Adapter
- Interface Supported
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - female
- Limited warranty - 3 years
- Designed For
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.60 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £11.58 |
StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F | In Stock | £10.50 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.05 |
StarTech.com DisplayPort to HDMI Video Adapter Converter | In Stock | £14.58 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.26 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £8.18 |
StarTech.com HDMI or DVI to DisplayPort Active Converter | In Stock | £69.12 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.55 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.62 |
StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter | In Stock | £20.93 |
StarTech.com 3ft DP to HDMI cable - 4K | In Stock | £12.98 |
StarTech.com 6 ft DP to HDMI cable - 4K | In Stock | £14.32 |
StarTech.com DisplayPort to HDMI - 4K | In Stock | £13.01 |
StarTech.com HDMI to DisplayPort Converter - 4K | In Stock | £36.00 |
StarTech.com 3m DisplayPort to HDMI Cable - 4K | In Stock | £18.60 |
StarTech.com DisplayPort to HDMI - 4K 60Hz | In Stock | £22.01 |
