StarTech.com DisplayPort to HDMI Cable
Quicklinx: HFNLWS00 Mfr#: 133DISPLAYPORTHDMI21
Length: 2m
Hurry, only 1 left in stock!
£41.82 ex VAT
£50.18 inc VAT
6ft (2m) DisplayPort to HDMI Adapter Cable, 8K 60Hz, 4K 144Hz, HDR10, DP 1.4 to HDMI 2.1 Active Video Converter, DisplayPort Desktop to HDMI Monitor, M/M - DisplayPort to HDMI Cord (133DISPLAYPORTHDMI21).
  • High-Resolution HDR Video
    This DP to HDMI Cable enables resolutions of up to 8K 60Hz and is HDMI 2.1 FRL complaint. It supports HDR10, HDCP 1.x/2.2/2.3, and DSC 1.1/1.2a. The adapter cable supports 7.1 channel audio with Dolby Atmos and DTS:X. *DSC support required to reach maximum resolution capabilities on Intel 11th Gen or later
  • Universal Compatibility
    The DisplayPort to HDMI Converter Cable is compatible with desktops from various brands such as Dell, HP, Lenovo, and more. It works with all hardware platforms and any operating system. The DP to HDMI Cable requires no drivers or software and works with dedicated graphics card from Nvidia and AMD.
  • Thoughtfully Designed
    Combining a video adapter and cable minimizes potential points of failure and signal loss. Adaptive receiver equalization optimizes the input signal and amplifies the output signal to ensure compatibility with high-resolution monitors. The cable is equipped with cage shielding to prevent Electromagnetic Interference (EMI).
StarTech.com 6ft (2m) DisplayPort to HDMI Adapter Cable, 8K 60Hz, 4K 144Hz, HDR10, DP 1.4 to HDMI 2.1 Active Video Converter, DisplayPort Desktop to HDMI Monitor, M/M - DisplayPort to HDMI Cord (133DISPLAYPORTHDMI21) - adapter cable - DisplayPort / HDMI - 2 m
Cable
Adapter cable - DisplayPort / HDMI
Length
2 m
Space grey
Connector
DisplayPort - male
Connector (Second End)
HDMI - male
DisplayPort 1.4
4K support, 8K support, active adapter
3-year warranty
Cable Type
Adapter cable 4K support, 8K support, active
Interface Supported
DisplayPort / HDMI
Jacket Material
PVC
DisplayPort 1.4
Length
2 m
Plated Connector
Nickel
Support HDR10, outer diameter 6mm, 7.1 audio channel support (HDMI), wide screen support, active converter
Space grey
Connector
20 pin DisplayPort - male
19 pin HDMI Type A - male
RoHS, WEEE
109 g
Shipping Weight
119 g
Limited warranty - 3 years
Length: 2m
