6ft (2m) DisplayPort to HDMI Adapter Cable, 8K 60Hz, 4K 144Hz, HDR10, DP 1.4 to HDMI 2.1 Active Video Converter, DisplayPort Desktop to HDMI Monitor, M/M - DisplayPort to HDMI Cord (133DISPLAYPORTHDMI21).
High-Resolution HDR Video
This DP to HDMI Cable enables resolutions of up to 8K 60Hz and is HDMI 2.1 FRL complaint. It supports HDR10, HDCP 1.x/2.2/2.3, and DSC 1.1/1.2a. The adapter cable supports 7.1 channel audio with Dolby Atmos and DTS:X. *DSC support required to reach maximum resolution capabilities on Intel 11th Gen or later -
Universal Compatibility
The DisplayPort to HDMI Converter Cable is compatible with desktops from various brands such as Dell, HP, Lenovo, and more. It works with all hardware platforms and any operating system. The DP to HDMI Cable requires no drivers or software and works with dedicated graphics card from Nvidia and AMD. -
Thoughtfully Designed
Combining a video adapter and cable minimizes potential points of failure and signal loss. Adaptive receiver equalization optimizes the input signal and amplifies the output signal to ensure compatibility with high-resolution monitors. The cable is equipped with cage shielding to prevent Electromagnetic Interference (EMI).
- Startech 6ft (2m) DisplayPort to HDMI Adapter Cable, 8K 60Hz, 4K 144Hz, HDR10, DP 1.4 to HDMI 2.1 Active Video Converter, DisplayPort Desktop to HDMI Monitor, M/M - DisplayPort to HDMI Cord (133DISPLAYPORTHDMI21) - adapter cable - DisplayPort / HDMI - 2 m
- Cable
- Adapter cable - DisplayPort / HDMI
- Cable Length
- 2 m
- Space grey
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - male
- DisplayPort 1.4
- 4K support, 8K support, active adapter
- 3-year warranty
- Cable Type
- Adapter cable 4K support, 8K support, active
- Interface Supported
- Jacket Material
- PVC
- DisplayPort 1.4
- Cable Length
- 2 m
- Plated Connector
- Nickel
- Support HDR10, active converter, outer diameter 6mm, 7.1 audio channel support (HDMI), wide screen support
- Space grey
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - male
- RoHS, WEEE
- 109 g
- Shipping Weight
- 119 g
- Limited warranty - 3 years
