6ft (2m) DisplayPort to HDMI Adapter Cable, 8K 60Hz, 4K 144Hz, HDR10, DP 1.4 to HDMI 2.1 Active Video Converter, DisplayPort Desktop to HDMI Monitor, M/M - DisplayPort to HDMI Cord (133DISPLAYPORTHDMI21).
High-resolution HDR video
This DP to HDMI cable enables resolutions of up to 8K 60 Hz and is HDMI 2.1 FRL complaint. It supports HDR10, HDCP 1.x/2.2/2.3, and DSC 1.1/1.2a. The adapter cable supports 7.1-channel audio with Dolby Atmos and DTS:X. -
Universal compatibility
The DisplayPort to HDMI converter cable is compatible with desktops from various brands. It works with all hardware platforms and any operating system. The DP to HDMI cable requires no drivers or software and works with dedicated graphics cards. -
Thoughtfully designed
Combining a video adapter and cable minimizes potential points of failure and signal loss. Adaptive receiver equalization optimizes the input signal and amplifies the output signal to ensure compatibility with high-resolution monitors. The cable is equipped with cage shielding to prevent electromagnetic interference (EMI).
- StarTech.com 6ft (2m) DisplayPort to HDMI Adapter Cable, 8K 60Hz, 4K 144Hz, HDR10, DP 1.4 to HDMI 2.1 Active Video Converter, DisplayPort Desktop to HDMI Monitor, M/M - DisplayPort to HDMI Cord (133DISPLAYPORTHDMI21) - adapter cable - DisplayPort / HDMI - 2 m
- Cable
- Adapter cable - DisplayPort / HDMI
- Length
- 2 m
- Space grey
- Connector
- DisplayPort - male
- Connector (Second End)
- HDMI - male
- DisplayPort 1.4
- 4K support, 8K support, active adapter
- 3-year warranty
- Cable Type
- Adapter cable 4K support, 8K support, active
- Interface Supported
- Jacket Material
- PVC
- DisplayPort 1.4
- Length
- 2 m
- Plated Connector
- Nickel
- Support HDR10, active converter, outer diameter 6mm, 7.1 audio channel support (HDMI), wide screen support
- Space grey
- Connector
- 20 pin DisplayPort - male
- 19 pin HDMI Type A - male
- RoHS, WEEE
- 109 g
- Shipping Weight
- 119 g
- Limited warranty - 3 years
