StarTech.com DisplayPort to HDMI - 4K
Quicklinx: BKBXWS00 Mfr#: DP2HD4KADAP
£14.32 ex VAT
£17.18 inc VAT
Connect your 4K HDMI display to a DP video source using this compact, passive adapter. This DisplayPort to HDMI adapter supports 4K video resolution, enabling you to connect DisplayPort devices, such as an Ultrabook or desktop computer, to a 4K HDMI display or projector.
You will be amazed at how this adapter flawlessly manages your graphics-intensive content. With support for resolutions up to 4K - four times the resolution of high-definition 1080p - its lossless performance makes the adapter the ideal solution for high-resource applications such as graphic design, CAD & CAM design, or health care imaging (MRI, radiology diagnostics, etc.).
Plus, the 4K adapter supports 1080p displays, which makes it a great accessory for home, office or other workspace applications.
This DP to HDMI adapter is extremely portable, with a lightweight, small-footprint design. It's the perfect accessory to carry with your Ultrabook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes the adapter ideal for BYOD (Bring Your Own Device) applications at the office, and enables you to arrive prepared when you're presenting to a potential client, teaching off-site, or traveling to meet with a customer.
StarTech.com DisplayPort to HDMI Converter - Passive DP Adapter - 4K - video converter
Video converter
Max Resolution
4096 x 2304
1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
3-year warranty
Video converter
Max Resolution
4096 x 2304 at 30 Hz
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
HDCP
Plug and Play, FCC, RoHS
20 g
Limited warranty - 3 years
60 °C
10 - 85%
BKBX StarTech.com 3m High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M In Stock £9.57
BKBX StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.14
BKBX StarTech.com 10m (33 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable In Stock £49.91
BKBX StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £19.37
BKBX StarTech.com DisplayPort to HDMI - 4K In Stock £14.32
Price Range Ex VAT: 0 - 50
