StarTech.com DisplayPort to HDMI - 4K 60Hz
Quicklinx: CGVPWS00 Mfr#: DP2HD4K60S
More than 50 In Stock
£23.95 ex VAT
£28.74 inc VAT
Connect your DP computer to an HDMI display using this converter, which supports UHD resolutions up to 4K at 60Hz. This DisplayPort to HDMI adapter lets you output HDMI video and audio from a DP device, with support for Ultra HD 4K at 60Hz.
The adapter lets you harness the video capabilities that are built into your DisplayPort connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while using multiple monitors to work on resource-demanding applications.
Unlike many 4K DisplayPort to HDMI adapters that only support a 30Hz refresh rate, this adapter works with HDMI 2.0 displays that can deliver output resolutions of up to 3840 x 2160p at 60Hz. Support for HDMI 2.0 means this adapter can support bandwidth up to 18Gbps, making it the ideal solution for performing high-resolution tasks such as editing 4K video.
The adapter is backward compatible with 1080p displays, which ensures that it will work with lower resolution displays such as TVs or projectors around your home or office.
The compact video adapter is highly portable and lightweight. It's the perfect accessory for your portable DP devices, fitting easily into your laptop bag or carrying case.
The portable adapter is a convenient addition when deploying company computers because it enables your employees to interface with BYOD (Bring Your Own Device) HDMI applications around the office, such as working at a hot-desk with an HDMI display or sharing your laptop's screen on a boardroom projector.
To ensure compatibility with any DisplayPort output, the DP adapter offers active conversion. Active video conversion is required to maintain 4K resolutions when converting DisplayPort to HDMI. An active DP adapter is ideal for outputting 1080p resolutions because it will work with graphics cards that can't output multimode DP++ signals, such as ATI Eyefinity cards.
For a hassle-free setup, the DisplayPort to HDMI adapter allows for plug-and-play installation without any additional software or drivers.
To achieve 4K resolution at 60 Hz, a DisplayPort 1.2 output and an HDMI 2.0 display are required.
  • Astonishing picture quality with support for Ultra HD 4K at 60 Hz
    The adapter lets you harness the video capabilities that are built into your DisplayPort connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while using multiple monitors to work on resource-demanding applications. Unlike many 4K DisplayPort to HDMI adapters that only support a 30Hz refresh rate, this adapter works with HDMI 2.0 displays that can deliver output resolutions of up to 3840 x 2160p at 60Hz. Support for HDMI 2.0 means this adapter can support bandwidth up to 18Gbps, making it the ideal solution for performing high-resolution tasks such as editing 4K video. The adapter is backward compatible with 1080p displays, which ensures that it will work with lower resolution displays such as TVs or projectors around your home or office.
  • Ultimate portability with a compact, lightweight design
    The compact video adapter is highly portable and lightweight. It's the perfect accessory for your portable DP devices, fitting easily into your laptop bag or carrying case. The portable adapter is a convenient addition when deploying company computers because it enables your employees to interface with BYOD (Bring Your Own Device) HDMI applications around the office, such as working at a hot-desk with an HDMI display or sharing your laptop's screen on a boardroom projector.
  • Hassle-free setup with an active adapter that features plug-and-play installation
    To ensure compatibility with any DisplayPort output, the DP adapter offers active conversion. Active video conversion is required to maintain 4K resolutions when converting DisplayPort to HDMI. An active DP adapter is ideal for outputting 1080p resolutions because it will work with graphics cards that can't output multimode DP++ signals, such as ATI Eyefinity cards. For a hassle-free setup, the DisplayPort to HDMI adapter allows for plug-and-play installation without any additional software or drivers. Note: To achieve 4K resolution at 60 Hz, a DisplayPort 1.4 output and an HDMI 2.0 display are required. The DP2HD4K60S is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com DisplayPort to HDMI Adapter - DP to HDMI - 4K 60Hz (DP2HD4K60S) - video converter
Video converter
1 x DisplayPort input - 20 pin DisplayPort , 1 x HDMI output - 19 pin HDMI Type A
3-year warranty
P/N: DK30C2DAGPD, TB32DP14, TB32DP2T, TB3DK2DHV, TB3DK2DHVUE
Video converter
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x HDMI output - 19 pin HDMI Type A - female
Plug and Play, FCC, RoHS, WEEE, RCM, DisplayPort 1.2, HDCP 2.2
Limited warranty - 3 years
5 °C
35 °C
CGVP StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £12.93
CGVP StarTech.com DisplayPort to HDMI Video Adapter Converter - M/F In Stock £11.76
CGVP StarTech.com DisplayPort to DVI Video Adapter Converter In Stock £10.99
CGVP StarTech.com DisplayPort to HDMI Video Adapter Converter In Stock £16.23
CGVP StarTech.com HDMI or DVI to DisplayPort Active Converter In Stock £81.92
CGVP StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £35.22
CGVP StarTech.com DisplayPort to HDMI 4K Audio / Video Converter – DP 1.2 to HDMI Active Adapter In Stock £20.93
CGVP StarTech.com Mini DisplayPort to HDMI 4K Audio / Video Converter – mDP 1.2 to HDMI Active Adapter In Stock £18.39
CGVP StarTech.com 6 ft DP to HDMI cable - 4K In Stock £16.30
CGVP StarTech.com HDMI to DisplayPort Converter - 4K In Stock £38.98
CGVP StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
CGVP StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.83
CGVP StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.29
CGVP StarTech.com Mini DisplayPort to HDMI - 4K In Stock £25.31
CGVP StarTech.com DisplayPort to HDMI - 4K 60Hz In Stock £23.95
CGVP StarTech.com DP to HDMI Adapter with HDR In Stock £25.19
CGVP StarTech.com DisplayPort to HDMI Cable In Stock £41.82
CGVP StarTech.com DP to HDMI Adapter Cable, 4K 3m In Stock £25.81
CGVP StarTech.com DP to HDMI Adapter Cable, 4K 1m In Stock £22.40
CGVP StarTech.com DP to HDMI Adapter Cable, 4K 2m In Stock £24.64
