Connect your DVI monitor to a DisplayPort equipped computer. The StarTech.com DP2DVI2 DVI/DisplayPort adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI2 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
- StarTech.com DisplayPort to DVI-D Adapter - 1920x1200 - Passive DVI Video Converter with Latching DP Connector (DP2DVI2) - DisplayPort adapter - 15.2 cm
- Length
- 15.2 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- DVI-I - female
- FCC, RoHS
- Black
- 3-year warranty
- Designed For
- P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
- Length
- 15.2 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 24+5 pin combined DVI - female
- FCC, RoHS
- 3-year warranty
- Designed For
- P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £8.72 |
StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £32.72 |
StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £25.85 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £10.24 |
StarTech.com 6 ft DisplayPort to DVI Cable - M/M | In Stock | £15.96 |
StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F | In Stock | £8.75 |
StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £23.57 |
StarTech.com DisplayPort to DVI Active Adapter | In Stock | £23.96 |
StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £107.20 |
StarTech.com 3 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black | In Stock | £13.17 |
StarTech.com 10 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 Black | In Stock | £21.14 |
StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £24.39 |
