StarTech.com DisplayPort to DVI Video Adapter Converter
Quicklinx: 6NZNWS00 Mfr#: DP2DVI2
More than 50 in stock
£10.18 ex VAT
£12.21 inc VAT
Connect your DVI monitor to a DisplayPort equipped computer. The StarTech.com DP2DVI2 DVI/DisplayPort adapter supports display resolutions of up to 1920x1200 allowing you to take full advantage of single link DVI capability. DP2DVI2 is a passive adapter that requires a DP++ port (DisplayPort++), meaning that DVI and HDMI signals can also be passed through the port.
StarTech.com DisplayPort to DVI-D Adapter - 1920x1200 - Passive DVI Video Converter with Latching DP Connector (DP2DVI2) - DisplayPort adapter - 15.2 cm
DisplayPort adapter
Length
15.2 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-I - female
FCC, RoHS
3-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
DisplayPort adapter
Length
15.2 cm
Connector
20 pin DisplayPort - male
24+5 pin combined DVI - female
FCC, RoHS
3-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK30CH2DEP, DK30CH2DEPUE, DK31C3HDPD, DK31C3HDPDUE, DVIDDMM1, DVIDDMM10M, DVIDDMM25, DVIDDMM2M, DVIDDMM3M, DVIDDMM5M, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE
Stock Status: In stock
