Connect your DVI Dual Link display to a DisplayPort video source, for high resolution applications. The DP2DVID2 DisplayPort to DVI (Dual-Link) Adapter actively converts the output signal from a DisplayPort video source for use with a DVI-D display (monitor, etc.) or projector, helping to eliminate the equipment costs of upgrading a DVI display to a newer model for the sake of compatibility.
The adapter supports high resolution video (up to 2560x1600), maintaining the outstanding graphical performance from a DisplayPort-equipped desktop video card, laptop or MacBook.
DP2DVID2 performs an active DisplayPort-DVI conversion that is suitable for video sources that output either multimode (DP++) or single-mode DisplayPort signals. This ensures the adapter can be used even with graphics cards that aren't capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
 - StarTech.com DisplayPort to DVI Adapter - Dual-Link - Active DVI-D Adapter for Your Monitor / Display - USB Powered - 2560x1600 (DP2DVID2) - DisplayPort / DVI adapter - 37 cm
 - USB power, active adapter, 2560 x 1600 (WQXGA) support, plastic housing, HBR2 support
- Length
 - 37 cm
- Connectors
 - 20 pin DisplayPort - male , 4 pin USB Type A (power only) - male
- Connectors (Second End)
 - 24+1 pin digital DVI - female
 - USB 2.0 / DisplayPort 1.2
 - Black
 - 3-year warranty
- Length
 - 37 cm
 - Black
 - 6.4 cm
 - 5.49 cm
 - 2.2 cm
 - 160 g
- Connectors
 - USB 2.0 / DisplayPort 1.2, FCC, RoHS, EDID compatible, HDCP
- Shipping Width
 - 17.4 cm
- Shipping Depth
 - 14.3 cm
- Shipping Height
 - 3.5 cm
- Shipping Weight
 - 232 g
 - 3-year warranty
                        StarTech.com 10 ft DisplayPort to DVI Video Adapter Converter Cable - M/M | In Stock | £21.26 |
                        StarTech.com 6 ft DisplayPort to DVI Video Converter Cable - M/M | In Stock | £23.94 |
                        StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.00 |
                        StarTech.com 6 ft DisplayPort to DVI Cable - M/M | In Stock | £5.59 |
                        StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F | In Stock | £8.52 |
                        StarTech.com DisplayPort to DVI Active Adapter | In Stock | £20.81 |
                        StarTech.com DisplayPort to DVI Dual Link Active Video Adapter Converter - DP to DVI-D - 2560x1600 | In Stock | £25.81 |
                        StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black | In Stock | £21.04 |
                        StarTech.com 3ft DP to DVI Converter Cable | In Stock | £14.55 |
                        StarTech.com mDP to Dual-Link DVI Adapter | In Stock | £17.48 |
