StarTech.com DisplayPort to 3x HDMI MST Hub
Quicklinx: BNNYWS00 Mfr#: MSTDP123HD
Ports: 3
£107.65 ex VAT
£129.18 inc VAT
This MST hub lets you connect three HDMI monitors to your DisplayPort (DP) 1.2 equipped Windows laptop or desktop.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. You can also mirror the same image onto multiple HDMI televisions or projectors for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MSTDP123HD will act as splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTDP123HD supports plug-and-play installation for a hassle-free setup.
  • Increase productivity with multiple screens
    Computers are portable, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier.
  • Configure your displays for any environment
StarTech.com MST Hub DisplayPort to HDMI Multi-Monitor Splitter - 3-Port MST Hub - DP 1.2 to 3x HDMI MST Hub (MSTDP123HD) - video/audio splitter - 3 ports
Video/audio splitter - 3 ports
Subtype
HDMI / DisplayPort
Ports
3 x HDMI
Plastic housing
AC 100/240 V
6.6 cm x 11.4 cm x 1.4 cm
119 g
Windows 10 (32/64 bits), Microsoft Windows 7 / 8 / 8.1 (32 bits), Microsoft Windows 7 / 8 / 8.1 (64 bits)
3-year warranty
Enclosure Type
Desktop
Subtype
HDMI / DisplayPort
Ports
3 x HDMI
Max Resolution
3840 x 2160 @ 30 Hz
Plastic housing
3 x HDMI output , 1 x DisplayPort input
External power adapter
AC 100/240 V
FCC, RoHS
6.6 cm
11.4 cm
1.4 cm
119 g
Limited warranty - 3 years
45 °C
50 - 90%
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BNNY StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.22
BNNY StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £72.46
BNNY StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £80.21
BNNY StarTech.com MST Hub - mDP to 2x DP In Stock £49.45
BNNY StarTech.com MST Hub - 4-Port DisplayPort In Stock £120.91
BNNY StarTech.com MST Hub - mDP to 4x DP In Stock £99.35
BNNY StarTech.com DisplayPort to 3x HDMI MST Hub In Stock £107.65
Ports: 3
Price Range Ex VAT: 100 - 150
