StarTech.com DisplayPort to 3x HDMI MST Hub
Quicklinx: BNNYWS00 Mfr#: MSTDP123HD
Ports: 3
£68.03 ex VAT
£81.63 inc VAT
This MST hub lets you connect three HDMI monitors to your DisplayPort (DP) 1.2 equipped Windows laptop or desktop.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. You can also mirror the same image onto multiple HDMI televisions or projectors for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MSTDP123HD will act as splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTDP123HD supports plug-and-play installation for a hassle-free setup.
  • Increase productivity with multiple screens
  • Configure your displays for any environment
  • Enjoy amazing video quality without draining system resources
    MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging. Note: When using a DisplayPort 1.1 video card the MSTDP123HD will act as splitter, automatically mirroring your video source across all displays. Resolution limitations apply. The MSTDP123HD supports plug-and-play installation for a hassle-free setup, and is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: MST shares 21.6 Gbps across all attached displays. Higher resolutions can restrict the available bandwidth with the remaining ports, please see our guideline below for determining an ideal resolution for your setup. Certain graphics adapters have limited MST support and will only output to three displays in total. If more than three monitors are attached the fourth will be disabled. Some monitors limit available resolution Average Resolution Bandwidth Allocation 1920x1080 (High-definition 1080p) @60hz - 22% 1920x1200 @60hz - 30% 2560x1440 @60hz - 35% 2560x1600 @60hz - 38% 3840 x 2160 (Ultra HD 4K) @30hz - 43% Note: Exceeding 100% will reduce functionality. Examples of Supported Resolution Configurations
StarTech.com 3-Port Multi Monitor Adapter, DisplayPort 1.2 to HDMI MST Hub, Triple 1080p HDMI Monitor, Video Splitter for Extended Desktop Mode on Windows PCs Only, DP to 3x HDMI MST Hub - Multi Stream Transport (MSTDP123HD) - video/audio splitter - 3 ports
Video/audio splitter - 3 ports
Subtype
HDMI / DisplayPort
Ports
3 x HDMI
Plastic housing
AC 100/240 V
6.6 cm x 11.4 cm x 1.4 cm
119 g
Microsoft Windows 7 / 8 / 8.1 (32 bits), Microsoft Windows 7 / 8 / 8.1 (64 bits), Windows 10 (32/64 bits)
3-year warranty
Enclosure Type
Desktop
Subtype
HDMI / DisplayPort
Ports
3 x HDMI
Max Resolution
3840 x 2160 @ 30 Hz
Plastic housing
3 x HDMI output , 1 x DisplayPort input
External power adapter
AC 100/240 V
FCC, RoHS
6.6 cm
11.4 cm
1.4 cm
119 g
Limited warranty - 3 years
45 °C
50 - 90%
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
BNNY StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
BNNY StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.74
BNNY StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £37.96
BNNY StarTech.com Multi Stream Transport Hub – Mini DisplayPort 1.2 to Triple Head DisplayPort MST Hub In Stock £32.34
BNNY StarTech.com MST Hub - mDP to 2x DP In Stock £19.04
BNNY StarTech.com mDP 1.2 to HDMI MST Hub In Stock £33.29
BNNY StarTech.com DC Power Adapter - 5V, 3A In Stock £12.31
BNNY StarTech.com 3 Port DisplayPort MST Hub - 3 x 4K - DP 1.4 Multi Monitor In Stock £31.71
BNNY StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet In Stock £15.69
BNNY StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
BNNY StarTech.com DP 1.4 to Dual HDMI MST Hub In Stock £29.07
Ports: 3
