This MST hub lets you connect three HDMI monitors to your DisplayPort (DP) 1.2 equipped Windows laptop or desktop.
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. You can also mirror the same image onto multiple HDMI televisions or projectors for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging.
Note: When using a DisplayPort 1.1 video card the MSTDP123HD will act as splitter, automatically mirroring your video source across all displays. Resolution limitations apply.
The MSTDP123HD supports plug-and-play installation for a hassle-free setup.
Increase productivity with multiple screens
The newest generations of computers are more portable than ever, which often means that you're left with fewer video outputs and smaller integrated screens. This MST hub solves both of these problems by letting you connect three additional displays to your computer, which makes multitasking much easier. -
Configure your displays for any environment
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. You can also mirror the same image onto multiple HDMI televisions or projectors for remote viewing applications such as digital signage. -
Enjoy amazing video quality without draining system resources
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. This unprecedented performance makes MST perfect for high-resolution applications such as graphic design, gaming and medical imaging. Note: When using a DisplayPort 1.1 video card the MSTDP123HD will act as splitter, automatically mirroring your video source across all displays. Resolution limitations apply. The MSTDP123HD supports plug-and-play installation for a hassle-free setup, and is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note: MST shares 21.6 Gbps across all attached displays. Higher resolutions can restrict the available bandwidth with the remaining ports, please see our guideline below for determining an ideal resolution for your setup. Certain graphics adapters have limited MST support and will only output to three displays in total. If more than three monitors are attached the fourth will be disabled. Some monitors limit available resolution Average Resolution Bandwidth Allocation 1920x1080 (High-definition 1080p) @60hz - 22% 1920x1200 @60hz - 30% 2560x1440 @60hz - 35% 2560x1600 @60hz - 38% 3840 x 2160 (Ultra HD 4K) @30hz - 43% Note: Exceeding 100% will reduce functionality. Examples of Supported Resolution Configurations
- StarTech.com 3-Port Multi Monitor Adapter, DisplayPort 1.2 to HDMI MST Hub, Triple 1080p HDMI Monitor, Video Splitter for Extended Desktop Mode on Windows PCs Only, DP to 3x HDMI MST Hub - Multi Stream Transport (MSTDP123HD) - video/audio splitter - 3 ports
- Video/audio splitter - 3 ports
- Subtype
- HDMI / DisplayPort
- Ports
- 3 x HDMI
- Plastic housing
- Power
- AC 100/240 V
- 6.6 cm x 11.4 cm x 1.4 cm
- 119 g
- Black
- System Requirements
- Microsoft Windows 7 / 8 / 8.1 (32 bits), Microsoft Windows 7 / 8 / 8.1 (64 bits), Windows 10 (32/64 bits)
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- Ports
- 3 x HDMI
- Max Resolution
- 3840 x 2160 @ 30 Hz
- Plastic housing
- 3 x HDMI output , 1 x DisplayPort input
- Power Device
- External power adapter
- Voltage Required
- AC 100/240 V
- Black
- FCC, RoHS
- OS Required
- 6.6 cm
- 11.4 cm
- 1.4 cm
- 119 g
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 50 - 90%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.92 |
StarTech.com 2m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £7.74 |
StarTech.com Multi Stream Transport Hub – DisplayPort 1.2 to Triple Head DisplayPort MST Hub | In Stock | £37.96 |
StarTech.com MST Hub - mDP to 2x DP | In Stock | £19.04 |
StarTech.com mDP 1.2 to HDMI MST Hub | In Stock | £33.29 |
StarTech.com DC Power Adapter - 5V, 3A | In Stock | £12.31 |
StarTech.com 3 Port DisplayPort MST Hub - 3 x 4K - DP 1.4 Multi Monitor | In Stock | £31.71 |
StarTech.com 2m/6.6 ft Premium High Speed HDMI Cable with Ethernet | In Stock | £15.69 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £12.98 |
StarTech.com DP 1.4 to Dual HDMI MST Hub | In Stock | £27.80 |
