StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200
Quicklinx: 9FSTWS00 Mfr#: DP2VGA3
More than 50 in stock
£17.15 ex VAT
£20.58 inc VAT
Connect a DisplayPort 1.2-equipped computer to a VGA Monitor or Projector. The DP2VGA3 DisplayPort 1.2 to VGA adapter lets you connect your DisplayPort-equipped desktop or laptop computer to a VGA monitor or projector, eliminating the expense of upgrading to a DisplayPort 1.2-capable display.
The DP to VGA adapter is fully compliant with the DisplayPort 1.2 revision, ensuring compatibility with newer DisplayPort enabled computer systems. The DisplayPort 1.2 adapter is also backward compatible with older DisplayPort revisions, ensuring this adapter will work with your DisplayPort computer. Plus, with support for resolutions up to 1920x1200 / 1080p you can convert your DisplayPort video source to work with your VGA projector or display without sacrificing video quality.
For a hassle-free setup the DisplayPort adapter allows for plug and play installation with no software or drivers required.
StarTech.com DisplayPort to VGA Adapter - 1920x1200 - Monitor Converter - display adapter - 10 cm
Display adapter
Active cable (signal regeneration)
Length
10 cm
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - female
FCC, RoHS
3-year warranty
P/N: MSTDP123DP
Display adapter
Length
10 cm
Connector
20 pin DisplayPort - male
15 pin HD D-Sub (HD-15) - female
FCC, RoHS
3-year warranty
P/N: MSTDP123DP
9FST StarTech.com 6 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £5.74
9FST StarTech.com 6 ft Monitor VGA Cable - HD15 M/M In Stock £4.11
9FST StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £22.13
9FST StarTech.com 10 ft VGA Monitor Cable - HD15 MM In Stock £4.64
9FST StarTech.com 15 ft Monitor VGA Cable - HD15 MM In Stock £5.07
9FST StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £15.75
9FST StarTech.com 1 ft Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £4.72
9FST StarTech.com 6 ft DisplayPort to VGA Cable - M/M In Stock £32.05
9FST StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £18.18
9FST StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.37
9FST StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £20.79
9FST StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £6.02
9FST StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £17.15
9FST StarTech.com DP to VGA Adapter with Audio In Stock £17.87
Price Range Ex VAT: 0 - 50
