StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200
Quicklinx: 9FSTWS00 Mfr#: DP2VGA3
10 In Stock
£16.47 ex VAT
£19.76 inc VAT
Connect a DisplayPort 1.2-equipped computer to a VGA Monitor or Projector. The DP2VGA3 DisplayPort 1.2 to VGA adapter lets you connect your DisplayPort-equipped desktop or laptop computer to a VGA monitor or projector, eliminating the expense of upgrading to a DisplayPort 1.2-capable display.
The DP to VGA adapter is fully compliant with the DisplayPort 1.2 revision, ensuring compatibility with newer DisplayPort enabled computer systems. The DisplayPort 1.2 adapter is also backward compatible with older DisplayPort revisions, ensuring this adapter will work with your DisplayPort computer. Plus, with support for resolutions up to 1920x1200 / 1080p you can convert your DisplayPort video source to work with your VGA projector or display without sacrificing video quality.
For a hassle-free setup the DisplayPort adapter allows for plug and play installation with no software or drivers required.
  • Crystal-Clear Picture Quality
    With support for video resolutions up to 1920x1200 or 1080p, you'll be surprised at the picture quality the adapter provides, even when connected to an older VGA monitor, projector or television. The adapter harnesses the video capabilities built into your DisplayPort connection to deliver every detail in stunning high-definition.
  • Works with Your Legacy VGA Displays & Projectors
    This DisplayPort video adapter makes your DP computer fully compatible with legacy VGA monitors or projectors in your home or around the office. You can use the converter to either connect to an existing VGA display or add a secondary monitor to your workstation, helping to boost your productivity.
  • Designed for Maximum Portability
    This DisplayPort to VGA dongle maximizes portability with a compact, lightweight design, making it the perfect travel accessory to carry with your DisplayPort devices. The ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office, delivering HD video presentations on-the-go or even staying connected at home. For added convenience, this DP to VGA converter supports plug-and-play connectivity and requires no additional software or drivers for a hassle-free setup. DP2VGA3 is backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com DisplayPort to VGA Display Adapter - 1080p 1920x1200 - Active DP to VGA (Male to Female) HD Video Converter for laptop/PC/Monitor (DP2VGA3) - display adapter - 10 cm
Display adapter
Active cable (signal regeneration)
Length
10 cm
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - female
FCC, RoHS
3-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, DKWG30DPHPD, DKWG30DPHPDU, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP124DP, MSTMDP122DP, MSTMDP124DP, SV231QDPU34K, TB32DP14, TB32DP2T, TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
Display adapter
Length
10 cm
Connector
20 pin DisplayPort - male
15 pin HD D-Sub (HD-15) - female
FCC, RoHS
3-year warranty
P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, DKWG30DPHPD, DKWG30DPHPDU, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, SV231QDPU34K, TB32DP14, TB32DP2T, TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
9FST StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £24.00
9FST StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £15.81
9FST StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £20.09
9FST StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £22.31
9FST StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £23.78
9FST StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M In Stock £7.88
9FST StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £16.47
9FST StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black In Stock £35.39
9FST StarTech.com DP to VGA Adapter with Audio In Stock £23.69
