Connect a DisplayPort 1.2-equipped computer to a VGA Monitor or Projector. The DP2VGA3 DisplayPort 1.2 to VGA adapter lets you connect your DisplayPort-equipped desktop or laptop computer to a VGA monitor or projector, eliminating the expense of upgrading to a DisplayPort 1.2-capable display.
The DP to VGA adapter is fully compliant with the DisplayPort 1.2 revision, ensuring compatibility with newer DisplayPort enabled computer systems. The DisplayPort 1.2 adapter is also backward compatible with older DisplayPort revisions, ensuring this adapter will work with your DisplayPort computer. Plus, with support for resolutions up to 1920x1200 / 1080p you can convert your DisplayPort video source to work with your VGA projector or display without sacrificing video quality.
For a hassle-free setup the DisplayPort adapter allows for plug and play installation with no software or drivers required.
Crystal-Clear Picture Quality
With support for video resolutions up to 1920x1200 or 1080p, you'll be surprised at the picture quality the adapter provides, even when connected to an older VGA monitor, projector or television. The adapter harnesses the video capabilities built into your DisplayPort connection to deliver every detail in stunning high-definition. -
Works with Your Legacy VGA Displays & Projectors
This DisplayPort video adapter makes your DP computer fully compatible with legacy VGA monitors or projectors in your home or around the office. You can use the converter to either connect to an existing VGA display or add a secondary monitor to your workstation, helping to boost your productivity. -
Designed for Maximum Portability
This DisplayPort to VGA dongle maximizes portability with a compact, lightweight design, making it the perfect travel accessory to carry with your DisplayPort devices. The ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office, delivering HD video presentations on-the-go or even staying connected at home. For added convenience, this DP to VGA converter supports plug-and-play connectivity and requires no additional software or drivers for a hassle-free setup. DP2VGA3 is backed by a 3-year StarTech.com warranty and free lifetime technical support.
- StarTech.com DisplayPort to VGA Display Adapter - 1080p 1920x1200 - Active DP to VGA (Male to Female) HD Video Converter for laptop/PC/Monitor (DP2VGA3) - display adapter - 10 cm
- Display adapter
- Active cable (signal regeneration)
- Length
- 10 cm
- Connector
- DisplayPort - male
- Connector (Second End)
- HD-15 (VGA) - female
- FCC, RoHS
- Black
- 3-year warranty
- Designed For
- P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, DKWG30DPHPD, DKWG30DPHPDU, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP124DP, MSTMDP122DP, MSTMDP124DP, SV231QDPU34K, TB32DP14, TB32DP2T, TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
- Display adapter
- Length
- 10 cm
- Black
- Connector
- 20 pin DisplayPort - male
- 15 pin HD D-Sub (HD-15) - female
- FCC, RoHS
- 3-year warranty
- Designed For
- P/N: DK30C2DPEP, DK30C2DPEPUE, DK30C2DPPD, DK30C2DPPDUE, DK31C3HDPD, DK31C3HDPDUE, DKM30CHDPD, DKM30CHDPDUE, DKWG30DPHPD, DKWG30DPHPDU, MST14DP123DP, MSTCDP122DP, MSTCDP123DP, MSTDP122DP, MSTDP123DP, MSTDP124DP, MSTMDP122DP, MSTMDP123DP, MSTMDP124DP, SV231QDPU34K, TB32DP14, TB32DP2T, TB3DK2DPM2, TB3DOCK2DPPD, TB3DOCK2DPPU
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £16.94 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £17.08 |
StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £17.24 |
StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £19.46 |
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £20.51 |
StarTech.com 1.5m High Speed HDMI Cable – Ultra HD 4k x 2k HDMI Cable – HDMI to HDMI M/M | In Stock | £6.05 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £14.91 |
StarTech.com DisplayPort to VGA / DVI / HDMI Adapter – 3-in-1 DP Converter – Black | In Stock | £31.58 |
StarTech.com DP to VGA Adapter with Audio | In Stock | £19.30 |
