Add a large 24" x 27.5" anti-static mat to your desktop or work station. StarTech.com's Desktop Anti-Static Mat helps you protect your valuable computer equipment from dangerous static electricity. This high quality anti-static mat is constructed from the highest quality static dissipative material, to ensure safe operation of your equipment.
The anti-static mat exceeds IBM and US military static control standards and measures 24x27.5in - perfect for placement under the CPU/VDT and keyboard.
Effective grounding
The Anti-Static Mat - 25" x 27.5" offers an essential solution for preventing electrostatic discharge during the assembly or repair of PCs and servers. Its beige design seamlessly integrates into any workspace, providing both functionality and aesthetic appeal -
Versatile compatibility
Designed to meet the needs of a wide range of users, this desktop anti-static mat is compatible with PC systems. It ensures a safe and static-free work environment for both home and office settings
- StarTech.com Anti-Static Mat - 25" x 27.5" Electrical Grounding Desk Pad - For Home or Work - Beige (M3013) - desktop anti-static mat
- Product Type
- Desktop anti-static mat
- Beige
- 70 cm x 50 cm x 2 mm
- 457 g
- Package Type
- Retail
- 2-year warranty
- Product Type
- 70 cm
- 50 cm
- 2 mm
- 457 g
- Beige
- Package Type
- Retail
- Limited warranty: - 2 years
StarTech.com ESD Anti Static Wrist Strap | In Stock | £7.18 |
StarTech.com Desktop Anti-Static Mat | In Stock | £20.88 |
StarTech.com 23x47in Anti Static Mat | In Stock | £48.73 |
StarTech.com 11x18in Anti Static Mat | In Stock | £27.27 |
