Add a large 24" x 27.5" anti-static mat to your desktop or work station. StarTech.com's Desktop Anti-Static Mat helps you protect your valuable computer equipment from dangerous static electricity. This high quality anti-static mat is constructed from the highest quality static dissipative material, to ensure safe operation of your equipment.
The anti-static mat exceeds IBM and US military static control standards and measures 24x27.5in - perfect for placement under the CPU/VDT and keyboard.
- StarTech.com Anti-Static Mat - 25" x 27.5" Electrical Grounding Desk Pad - For Home or Work - Beige (M3013) - desktop anti-static mat
- Product Type
- Desktop anti-static mat
- Beige
- 70 cm x 50 cm x 2 mm
- 457 g
- Package Type
- Retail
- 2-year warranty
- Product Type
- 70 cm
- 50 cm
- 2 mm
- 457 g
- Beige
- Package Type
- Retail
- Limited warranty: - 2 years
StarTech.com ESD Anti Static Wrist Strap | In Stock | £7.40 |
StarTech.com Desktop Anti-Static Mat | In Stock | £20.76 |
StarTech.com 23x47in Anti Static Mat | In Stock | £48.44 |
StarTech.com 11x18in Anti Static Mat | In Stock | £27.42 |
