This universal tablet stand lets you integrate your tablet seamlessly into any workspace by clamping it to your desktop or work surface.
Customizable positioning
With this highly adjustable tablet stand, you'll be able to integrate your tablet into your workspace for maximum comfort and convenience. The stand features an articulating arm that enables you to easily position your tablet at the perfect height and depth for any application. -
Hassle-free installation
You can easily secure this tablet stand to your work surface, by clamping it onto your desk. Plus, the built-in arm discreetly manages your charging cable for a tidy, professional workspace, that enables you to charge your tablet while it's mounted. -
Maximum durability
This sturdy tablet holder ensures a secure home for your tablet with a solid-steel design that won't drop your tablet if it's bumped or knocked. The tablet stand combines this durable design with a sleek, professional finish that will look great in your home, office or storefront.
- StarTech.com Desk-Mount Tablet Arm - Articulating Tablet Mount - For 9" to 11" Tablets - iPad or Android Tablet Holder - Lockable - Steel mounting kit - adjustable arm - for tablet - white - TAA Compliant
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- Tilt
- 180°
- Pan
- 280°
- Rotation
- 360°
- Adjustments
- 1.774 kg
- Recommended Use
- Tablet
- Recommended Display Size
- 9"-11"
- Max Load Weight
- 1 kg
- Material
- Plastic, steel
- White
- TAA Compliant
- Package Content
- Allen wrench (3mm), keys, desk clamp, security wrench, 2 x cable-management clips, EVA cushion, allen wrench (2.5mm)
- 2-year warranty
- Designed For
- P/N: DK30CHPH, STSCART
- 1.774 kg
- Material
- Plastic, steel
- White
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- Tablet
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 9"-11"
- Tilt
- 180°
- Pan
- 280°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 1 kg
- TAA Compliant
- Limited warranty - 2 years
- Designed For
StarTech.com 11 Piece PC Computer Tool Kit with Carrying Case | In Stock | £14.09 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £9.01 |
StarTech.com Mobile Sit Stand Workstation | In Stock | £244.57 |
StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black | In Stock | £8.64 |
StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black | In Stock | £10.10 |
StarTech.com 1 m / 3.3 ft USB C Cable – Black | In Stock | £8.89 |
StarTech.com Secure Tablet Stand w/Cable Lock, Locking 7.9-13"Tablet | In Stock | £79.68 |
