StarTech.com Desk Mountable Tablet Stand
Quicklinx: CZC7WS00 Mfr#: ARMTBLTIW
Accessory Type: Stand
£106.46 ex VAT
£127.75 inc VAT
This universal tablet stand lets you integrate your tablet seamlessly into any workspace by clamping it to your desktop or work surface.
  • Customizable positioning
    With this highly adjustable tablet stand, you'll be able to integrate your tablet into your workspace for maximum comfort and convenience. The stand features an articulating arm that enables you to easily position your tablet at the perfect height and depth for any application.
  • Hassle-free installation
    You can easily secure this tablet stand to your work surface, by clamping it onto your desk. Plus, the built-in arm discreetly manages your charging cable for a tidy, professional workspace, that enables you to charge your tablet while it's mounted.
  • Maximum durability
    This sturdy tablet holder ensures a secure home for your tablet with a solid-steel design that won't drop your tablet if it's bumped or knocked. The tablet stand combines this durable design with a sleek, professional finish that will look great in your home, office or storefront.
StarTech.com Desk-Mount Tablet Arm - Articulating Tablet Mount - For 9" to 11" Tablets - iPad or Android Tablet Holder - Lockable - Steel mounting kit - adjustable arm - for tablet - white - TAA Compliant
Mounting kit (adjustable arm) - desk-mountable
Tilt
180°
Pan
280°
Rotation
360°
Adjustments
1.774 kg
Recommended Use
Tablet
Recommended Display Size
9"-11"
Max Load Weight
1 kg
Material
Plastic, steel
White
TAA Compliant
Package Content
Allen wrench (3mm), keys, desk clamp, security wrench, 2 x cable-management clips, EVA cushion, allen wrench (2.5mm)
P/N: DK30CHPH, STSCART
1.774 kg
Material
Plastic, steel
White
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
Tablet
Placing / Mounting
Desk-mountable
Cable Management
Integrated cable management
9"-11"
Tilt
180°
Pan
280°
Rotation
360°
Adjustments
Max Load Weight
1 kg
TAA Compliant
CZC7 StarTech.com 11 Piece PC Computer Tool Kit with Carrying Case In Stock £14.01
CZC7 StarTech.com Lightning/Micro USB Cable In Stock £19.13
CZC7 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £10.84
CZC7 StarTech.com Mobile Sit Stand Workstation In Stock £266.49
CZC7 StarTech.com 1 m / 3.3 ft USB 2.0 to USB C Cable – Black In Stock £10.00
CZC7 StarTech.com 2 m / 6.6 ft USB 2.0 to USB C Cable – Black In Stock £12.01
CZC7 StarTech.com 1 m / 3.3 ft USB C Cable – Black In Stock £9.84
