This desk mount monitor arm enables you to mount and raise a monitor with a maximum screen size of 32" (16:9) or 49" (32:9) ultra-wide. Its solid steel construction allows this monitor arm to support up to 8kg with two mounting solutions (C-Clamp or Grommet mount) to securely attach your monitor to your desk.
Full motion articulation
Setup an ergonomic work environment and reclaim valuable workspace on your desk. The adjustable monitor mount lets you extend the arm a full 590mm from the pole. The full motion arm moves freely provides a wide range of motion across multiple axes. You can tilt the monitor +90/-85 degrees, swivel +90/-90 degrees, and even rotate 360 degrees, to find the ideal viewing angle. Switch back and forth from landscape to portrait orientation at any time. Featuring spring-assisted height adjustment, the display mount lets you raise or lower your monitor up to 341mm with smooth and effortless positioning by hand. -
Organized workspace
This single desk monitor arm enables you to free up space by letting you mount your monitor to your desk, table, or countertop. In addition, it features integrated cable management channels along the arm, and cable management clips to route your cables and maintain an organized and professional look on your workstation. -
Easy installation
With the detachable VESA plates with quick-release clips, you can mount your display to the mount with ease. Either clamp the mount to the side of a desk up to 85mm thick, table or mount it through a grommet hole on desks up to 70mm thick.
- StarTech.com Desk Mount Monitor Arm for Single VESA Display up to 32" or 49" Ultrawide 8kg/17.6lb, Full Motion Articulating & Height Adjustable w/ Cable Management, C-Clamp, Grommet Mount - Single Monitor Arm mounting kit - full-motion adjustable arm - for Monitor
- Product Type
- Mounting kit (full-motion adjustable arm) - desk-mountable
- Mounting Components
- Arm assembly, VESA mount
- 29 cm x 48.5 cm x 14 cm
- Tilt
- -85° to 90°
- Lift
- 34 cm
- Rotation
- 360°
- Swivel
- -90° to 90°
- Adjustments
- Height, tilt, rotation
- 4.2 kg
- Recommended Use
- Monitor
- Recommended Display Size
- 32"-49"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Solid steel
- Package Content
- Cable management clip, pole assembly, hex key (3mm), hex key (4mm), 4 x M4 x 12 mm screws, 4 x M4 x 30 mm screws, 4 x spacers, grommet plate, hex key (5mm), 3 x M5 x 6 mm screws, cable management attachment
- 5-year warranty
- 29 cm
- 48.5 cm
- 14 cm
- 4.2 kg
- Material
- Solid steel
- Package Content
AV Furniture
- Mounting kit
- Design
- Full-motion adjustable arm
- Recommended Use
- Monitor
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 32"-49"
- Tilt
- -85° to 90°
- Lift
- 34 cm
- Rotation
- 360°
- Swivel
- -90° to 90°
- Adjustments
- Max Load Weight
- 8 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 29 cm x 48.5 cm x 14 cm / 4.2 kg
- Limited warranty - 5 years
StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay | In Stock | £3.02 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £70.33 |
StarTech.com Thin Client Mount - VESA | In Stock | £22.67 |
StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 | In Stock | £60.64 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £53.69 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £60.20 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.59 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.52 |
StarTech.com Monitor Desk Mount, VESA | In Stock | £113.36 |
StarTech.com Monitor Desk Mount, VESA | In Stock | £100.98 |
StarTech.com Desk Mount Monitor Arm/Max 32" | In Stock | £161.49 |
