StarTech.com Desk Mount Monitor Arm
Quicklinx: GKN9WS00 Mfr#: ARMPIVOTE2
Accessory Type: Mount
16 In Stock
£61.33 ex VAT
£73.59 inc VAT
This desk mount monitor arm enables you to mount and raise a monitor with a maximum screen size of 32" (16:9) or 49" (32:9) ultra-wide. Its solid steel construction allows this monitor arm to support up to 8kg with two mounting solutions (C-Clamp or Grommet mount) to securely attach your monitor to your desk.
  • Full motion articulation
    Setup an ergonomic work environment and reclaim valuable workspace on your desk. The adjustable monitor mount lets you extend the arm a full 590mm from the pole. The full motion arm moves freely provides a wide range of motion across multiple axes. You can tilt the monitor +90/-85 degrees, swivel +90/-90 degrees, and even rotate 360 degrees, to find the ideal viewing angle. Switch back and forth from landscape to portrait orientation at any time. Featuring spring-assisted height adjustment, the display mount lets you raise or lower your monitor up to 341mm with smooth and effortless positioning by hand.
  • Organized workspace
    This single desk monitor arm enables you to free up space by letting you mount your monitor to your desk, table, or countertop. In addition, it features integrated cable management channels along the arm, and cable management clips to route your cables and maintain an organized and professional look on your workstation.
  • Easy installation
    With the detachable VESA plates with quick-release clips, you can mount your display to the mount with ease. Either clamp the mount to the side of a desk up to 85mm thick, table or mount it through a grommet hole on desks up to 70mm thick.
StarTech.com Desk Mount Monitor Arm for Single VESA Display up to 32" or 49" Ultrawide 8kg/17.6lb, Full Motion Articulating & Height Adjustable w/ Cable Management, C-Clamp, Grommet Mount - Single Monitor Arm mounting kit - full-motion adjustable arm - for Monitor
Mounting kit (full-motion adjustable arm) - desk-mountable
Mounting Components
Arm assembly, VESA mount
29 cm x 48.5 cm x 14 cm
Tilt
-85° to 90°
Lift
34 cm
Rotation
360°
Swivel
-90° to 90°
Adjustments
Height, tilt, rotation
4.2 kg
Recommended Use
Monitor
Recommended Display Size
32"-49"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Solid steel
Package Content
Cable management clip, pole assembly, hex key (3mm), hex key (4mm), 4 x M4 x 12 mm screws, 4 x M4 x 30 mm screws, 4 x spacers, grommet plate, hex key (5mm), 3 x M5 x 6 mm screws, cable management attachment
5-year warranty
29 cm
48.5 cm
14 cm
4.2 kg
Material
Solid steel
Package Content
AV Furniture
Mounting kit
Mounting Components
Design
Full-motion adjustable arm
Recommended Use
Monitor
Placing / Mounting
Desk-mountable
Cable Management
Integrated cable management
32"-49"
Tilt
-85° to 90°
Lift
34 cm
Rotation
360°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
29 cm x 48.5 cm x 14 cm / 4.2 kg
Limited warranty - 5 years
GKN9 StarTech.com 3.5in Universal Hard Drive Mounting Bracket Adapter for 5.25in Bay In Stock £3.01
GKN9 StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £69.47
GKN9 StarTech.com Thin Client Mount - VESA In Stock £23.55
GKN9 StarTech.com USB-C Multiport Adapter HDMI - SD Reader - 2xA 1xC - PD3.0 In Stock £60.09
GKN9 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.28
GKN9 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
GKN9 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
GKN9 StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.60
GKN9 StarTech.com Monitor Desk Mount, VESA In Stock £117.24
