Monitor Mount For up to 34" VESA Mount Displays Integrated Cable Management 2-Year Warranty. Save space with this premium desk mount monitor arm, by suspending your screen above your desk.
Versatile Use
Use the single arm monitor mount to mount your VESA mount monitor (75x75, 100x100) up to 34".
Sleek and Stable Design
Made of aluminum, the VESA mount monitor stand provides stable support for your display, with a weight capacity of up to 17.6 lb. (8 kg). Built-in USB 3.0 ports provide convenient connectivity for your computer.
The arm extends 20.2" (514 mm) to allow a wide range of motion. Move the monitor holder arm effortlessly side to side to adjust your screen.
With its articulating arm, the monitor mount makes it easy to find the right viewing angle. Pan +90/-90 degrees left or right and tilt your display +90/-90 degrees up or down. For landscape or portrait viewing, rotate your display +90/-90 degrees.
Height Adjustment
Work in comfort with this height adjustable monitor stand that lets you raise or lower the monitor arm along the pole, up to 24.4" (620 mm).
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales
The ARMPIVOT2USB3 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com Desk Mount Monitor Arm with 2x USB 3.0 ports, Pole Mount Full Motion Single Arm Monitor Mount up to 17.6lbs/8kg VESA Display, Ergonomic Articulating Monitor Arm, Clamp/Grommet - Small Footprint Design (ARMPIVOT2USB3) mounting kit - for Monitor - black
- Product Type
- Mounting kit - desk-mountable
- Mounting Components
- Articulating arm, desk clamp mount, grommet clamp
- Integrated Devices
- 2-ports USB 3.0 hub
- 35 cm x 59.4 cm x 62 cm
- Tilt
- -90° to 90°
- Rotation
- -90° to 90°
- Swivel
- -90° to 90°
- Adjustments
- Height, tilt, swivel, rotation
- 3.25 kg
- Recommended Use
- Monitor
- Recommended Display Size
- 17"-34"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Heavy duty aluminium
- Black
- Package Content
- 4 x M4x12 screws, 4 x washers, 4 x M5x12 screws, hex key (3mm), grommet plate, hex key (6mm), cable management clip, grommet screw
- 2-year warranty
- 35 cm
- 59.4 cm
- 62 cm
- 3.25 kg
- Material
- Black
- Package Content
AV Furniture
- Mounting kit
- Recommended Use
- Monitor
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 17"-34"
- Tilt
- -90° to 90°
- Rotation
- -90° to 90°
- Swivel
- -90° to 90°
- Adjustments
- Max Load Weight
- 8 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 43.5 cm x 24 cm x 11.7 cm / 4.15 kg
- Limited warranty - 2 years
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £70.33 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.04 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £54.54 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £61.12 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.54 |
