StarTech.com Desk Mount Monitor Arm
Quicklinx: JFXKWS00 Mfr#: ARMPIVOT2
Accessory Type: Mount
£82.02 ex VAT
£98.42 inc VAT
Monitor Mount For up to 34" VESA Mount Displays Integrated Cable Management 2-Year Warranty. Save space with this premium desk mount monitor arm, by suspending your screen above your desk.
Versatile Use
Use the single arm monitor mount to mount your VESA mount monitor (75x75, 100x100) up to 34".
Sleek and Stable Design
Made of aluminum, the VESA mount monitor stand provides stable support for your display, with a weight capacity of up to 17.6 lb. (8 kg). Built-in USB 3.0 ports provide convenient connectivity for your computer.
The arm extends 20.2" (514 mm) to allow a wide range of motion. Move the monitor holder arm effortlessly side to side to adjust your screen.
With its articulating arm, the monitor mount makes it easy to find the right viewing angle. Pan +90/-90 degrees left or right and tilt your display +90/-90 degrees up or down. For landscape or portrait viewing, rotate your display +90/-90 degrees.
Height Adjustment
Work in comfort with this height adjustable monitor stand that lets you raise or lower the monitor arm along the pole, up to 24.4" (620 mm).
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales
The ARMPIVOT2USB3 is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com Desk Mount Monitor Arm with 2x USB 3.0 ports, Pole Mount Full Motion Single Arm Monitor Mount up to 17.6lbs/8kg VESA Display, Ergonomic Articulating Monitor Arm, Clamp/Grommet - Small Footprint Design (ARMPIVOT2USB3) mounting kit - for Monitor - black
Mounting kit - desk-mountable
Mounting Components
Articulating arm, desk clamp mount, grommet clamp
Integrated Devices
2-ports USB 3.0 hub
35 cm x 59.4 cm x 62 cm
Tilt
-90° to 90°
Rotation
-90° to 90°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
3.25 kg
Recommended Use
Monitor
Recommended Display Size
17"-34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Heavy duty aluminium
Package Content
4 x M4x12 screws, 4 x washers, 4 x M5x12 screws, hex key (3mm), grommet plate, hex key (6mm), cable management clip, grommet screw
35 cm
59.4 cm
62 cm
3.25 kg
Material
Package Content
AV Furniture
Mounting kit
Mounting Components
Recommended Use
Monitor
Placing / Mounting
Desk-mountable
Integrated Devices
2-ports USB 3.0 hub
Cable Management
Integrated cable management
17"-34"
Tilt
-90° to 90°
Rotation
-90° to 90°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
43.5 cm x 24 cm x 11.7 cm / 4.15 kg
JFXK StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £70.33
JFXK StarTech.com Thin Client Mount - VESA In Stock £22.53
JFXK StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £53.32
JFXK StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £59.75
JFXK StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.01
JFXK StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.52
