StarTech.com Desk Mount Monitor Arm - Steel
Quicklinx: CRY5WS00 Mfr#: ARMPIVOTB
Accessory Type: Mount
40 In Stock
£52.82 ex VAT
£63.38 inc VAT
Free up desk space and position your monitor for comfortable viewing. Save valuable desk space and position your monitor in a more comfortable viewing position. This durable desk-mount monitor arm makes it easy to suspend your display above your work area. It features an articulating arm that enables you to tilt, swivel and rotate your screen, to create a more ergonomic workspace and enhance productivity.
The single-monitor mount enables you to free up desk space by raising your screen off of your desk. It gives you more room to work by removing the monitor's bulky base from your desk surface. It's a quick and cost-effective way to maximize your available desk space, which makes for a more comfortable workstation and a more productive work environment.
The articulating arm gives you maximum workspace flexibility. You can extend the arm up to 17" (428 mm), along with swivel (180 degrees) and tilt (up to 90 degrees) adjustments that make it easy to find the perfect viewing angle. The arm offers smooth 360-degree screen rotation, so it's easy to switch from landscape to portrait orientation, to best meet your work requirements. You can also adjust the height of your monitor along the pole to your desired viewing position, to a maximum height of 17.7" (450 mm).
With its heavy-duty solid steel construction, the monitor mount provides long-lasting performance. The monitor arm supports a flat-panel display 13" to 27" (330 to 685.8 mm) in size and up to 17.6 lb. (8 kg) in weight.
The single-monitor arm makes it easy to mount your VESA mount compatible display above your desk, table or other surfaces, using the included C-clamp or grommet mount. For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor in place and tighten the screw. To help keep your work area free of clutter, the monitor arm also features cable clips that keep your cables neatly out of sight.
  • Versatile adjustments
    The monitor arm features multiple adjustments, including height, pan, and rotation, enabling users to set the desired viewing angle and position for comfort.
  • Strong and durable construction
    Constructed from sturdy steel, this monitor arm supports displays weighing up to 8 kg, providing reliable stability and performance.
  • Space-saving design
    By mounting the monitor above the desk, this arm optimizes desk space, allowing for a cleaner and more organized workspace.
  • Integrated cable management
    The arm includes a cable management system that keeps wires organized and out of the way, reducing clutter and improving aesthetics.
  • Wide range of motion
    The arm allows for a tilt range of -45° to 45°, a pan of 180°, and a full 360° rotation, giving users the flexibility to adjust their displays.
StarTech.com Desk Mount Monitor Arm for up to 34" VESA Compatible Displays, Articulating Pole Mount with Single Monitor Arm, Ergonomic Height Adjustable, Desk Clamp or Grommet, Black - Small Footprint Design (ARMPIVOTB) adjustable arm - for LCD display
Adjustable arm
16 cm x 46.2 cm x 10.8 cm
Tilt
-45° to 45°
Pan
180°
Lift
42.8 cm
Rotation
360°
Adjustments
Height, pan, rotation
3 kg
Recommended Use
LCD display
Recommended Display Size
34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Steel
5-year warranty
P/N: ARMSTSLG
16 cm
46.2 cm
10.8 cm
3 kg
Material
Steel
AV Furniture
Adjustable arm
Recommended Use
LCD display
Cable Management
34"
Tilt
-45° to 45°
Pan
180°
Lift
42.8 cm
Rotation
360°
Adjustments
Max Load Weight
8 kg
Limited warranty - 5 years
P/N: ARMSTSLG
CRY5 StarTech.com Sit-to-Stand Workstation In Stock £243.11
CRY5 StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £71.48
CRY5 StarTech.com Thin Client Mount - VESA In Stock £23.55
CRY5 StarTech.com Under Desk Keyboard Tray In Stock £53.93
CRY5 StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £51.28
CRY5 StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £58.71
CRY5 StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £75.65
CRY5 StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.60
CRY5 StarTech.com Monitor Desk Mount, VESA In Stock £117.48
