Free up desk space and position your monitor for comfortable viewing. Save valuable desk space and position your monitor in a more comfortable viewing position. This durable desk-mount monitor arm makes it easy to suspend your display above your work area. It features an articulating arm that enables you to tilt, swivel and rotate your screen, to create a more ergonomic workspace and enhance productivity.
The single-monitor mount enables you to free up desk space by raising your screen off of your desk. It gives you more room to work by removing the monitor's bulky base from your desk surface. It's a quick and cost-effective way to maximize your available desk space, which makes for a more comfortable workstation and a more productive work environment.
The articulating arm gives you maximum workspace flexibility. You can extend the arm up to 17" (428 mm), along with swivel (180 degrees) and tilt (up to 90 degrees) adjustments that make it easy to find the perfect viewing angle. The arm offers smooth 360-degree screen rotation, so it's easy to switch from landscape to portrait orientation, to best meet your work requirements. You can also adjust the height of your monitor along the pole to your desired viewing position, to a maximum height of 17.7" (450 mm).
With its heavy-duty solid steel construction, the monitor mount provides long-lasting performance. The monitor arm supports a flat-panel display 13" to 27" (330 to 685.8 mm) in size and up to 17.6 lb. (8 kg) in weight.
The single-monitor arm makes it easy to mount your VESA mount compatible display above your desk, table or other surfaces, using the included C-clamp or grommet mount. For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor in place and tighten the screw. To help keep your work area free of clutter, the monitor arm also features cable clips that keep your cables neatly out of sight.
Versatile adjustments
The monitor arm features multiple adjustments, including height, pan, and rotation, enabling users to set the desired viewing angle and position for comfort. -
Strong and durable construction
Constructed from sturdy steel, this monitor arm supports displays weighing up to 8 kg, providing reliable stability and performance. -
Space-saving design
By mounting the monitor above the desk, this arm optimizes desk space, allowing for a cleaner and more organized workspace. -
Integrated cable management
The arm includes a cable management system that keeps wires organized and out of the way, reducing clutter and improving aesthetics. -
Wide range of motion
The arm allows for a tilt range of -45° to 45°, a pan of 180°, and a full 360° rotation, giving users the flexibility to adjust their displays.
- StarTech.com Desk Mount Monitor Arm for up to 34" VESA Compatible Displays, Articulating Pole Mount with Single Monitor Arm, Ergonomic Height Adjustable, Desk Clamp or Grommet, Black - Small Footprint Design (ARMPIVOTB) adjustable arm - for LCD display
- Product Type
- Adjustable arm
- 16 cm x 46.2 cm x 10.8 cm
- Tilt
- -45° to 45°
- Pan
- 180°
- Lift
- 42.8 cm
- Rotation
- 360°
- Adjustments
- Height, pan, rotation
- 3 kg
- Recommended Use
- LCD display
- Recommended Display Size
- 34"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Steel
- 5-year warranty
- Designed For
- P/N: ARMSTSLG
- 16 cm
- 46.2 cm
- 10.8 cm
- 3 kg
- Material
- Steel
AV Furniture
- Adjustable arm
- Recommended Use
- LCD display
- Cable Management
- Integrated cable management
- 34"
- Tilt
- -45° to 45°
- Pan
- 180°
- Lift
- 42.8 cm
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 8 kg
- Limited warranty - 5 years
- Designed For
- P/N: ARMSTSLG
StarTech.com Sit-to-Stand Workstation | In Stock | £121.36 |
StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 | In Stock | £68.98 |
StarTech.com Thin Client Mount - VESA | In Stock | £22.13 |
StarTech.com Under Desk Keyboard Tray | In Stock | £52.06 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £52.39 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.71 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.65 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.34 |
StarTech.com Monitor Desk Mount, VESA | In Stock | £110.60 |
StarTech.com Monitor Desk Mount, VESA | In Stock | £98.51 |
