StarTech.com Desk Mount Laptop Arm or 34" Monitor VESA Mount
Quicklinx: GFGTWS00 Mfr#: ARMUNONB1
Accessory Type: Monitor stand, Monitor stand
£92.48 ex VAT
£110.97 inc VAT
Monitor Arm with Laptop Tray - Up to 34" monitors & 8kg in weight - C-Clamp Mounting
This Desktop Mount Laptop Arm enables you to raise your laptop off your desk and position it to increase ergonomics and productivity. Alternatively, you can mount a monitor up to 34" (16:9 or 21:9). The laptop/monitor arm supports up to 17.7lb / 8kg in weight, and it features cable management, one-touch/spring-assisted height adjustments along the 12.2" pole while extending up to a total height of 22" from the surface of the desk.
Laptop and Monitor Support
The laptop tray offers an area of 12.6"x9.5" to support your laptop up to 17.7lb/8kg, and it is fully adjustable to your viewing angle and height. When not using this arm as a laptop mount, you can mount monitors up to 34".
The VESA mount offers a full range of motion that will adjust to your setup and ergonomics needs, When using it as a notebook mount, your laptop will need additional security at steeper angles (not included).
Create an ergonomic setup
This full motion monitor arm lets you extend, tilt, and swivel your monitor and laptop with a full range of motion across multiple axes, with spring-assisted height adjustments for effortless positioning. It makes it easy to create an ergonomic work environment that's tailored to your specific needs.
The monitor arm is perfect for smaller work environments, like cubicles, providing everything you need while using less space.
Easy Installation
Install this laptop/monitor arm along the edge of your desk, table or counter using the C-clamp that can be tightened by hand. And it supports desks with up to 3.3 in (8.5 cm) in thickness.
ARMUNONB1 is backed by a StarTech.com 5-year warranty and free lifetime technical support.
  • Laptop and monitor support
    The laptop tray offers an area of 12.6" x 9.5" to support your laptop up to 17.7 lbs./8kg, and it is fully adjustable to your viewing angle and height. When not using this arm as a laptop mount, you can mount monitors up to 34". The VESA mount offers a full range of motion that will adjust to your setup and ergonomics needs.
  • Create an ergonomic setup
    This full-motion monitor arm lets you extend, tilt, and swivel your monitor and laptop with a full range of motion across multiple axes, with spring-assisted height adjustments for effortless positioning. It makes it easy to create an ergonomic work environment that's tailored to your specific needs. The monitor arm is perfect for smaller work environments, such as cubicles, providing everything you need while using less space.
  • Easy installation
    Install this laptop/monitor arm along the edge of your desk, table, or counter using the C-clamp that can be tightened by hand. And it supports desks with up to 3.3 in (8.5 cm) in thickness.
StarTech.com Desk Mount Laptop Arm, Full Motion Articulating Arm for Laptop or Single 34 inch Monitor, VESA Mount Laptop Tray Bracket, Ergonomic Adjustable Notebook Stand, Desk-Clamp - Tilt/Swivel/Rotate (ARMUNONB1) stand - full-motion adjustable arm - for monitor / notebook - black
Stand (full-motion adjustable arm) - C-clamp (10-85 mm)
57 cm x 32 cm x 31 cm
Tilt
-85° to 90°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
4.6 kg
Recommended Use
Monitor / notebook
Recommended Display Size
34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Aluminium
Package Content
Hex key (3mm), wrench, notebook tray, rubber pads, 4 x M5 x 12 mm screws, swivel arm, pole assembly, 4 x M5 nuts, spring arm assembly, 2 x cable management clips, M6 x 25mm screw assembly, decorative cap, 5mm hex key with screwdriver
5-year warranty
57 cm
32 cm
31 cm
4.6 kg
Material
Aluminium
Package Content
AV Furniture
Stand
Design
Full-motion adjustable arm
Recommended Use
Monitor / notebook
Placing / Mounting
C-clamp (10-85 mm)
Cable Management
Integrated cable management
34"
Tilt
-85° to 90°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
Dimensions
Tray - width: 32 cm, depth: 24 cm
47.6 cm x 25.2 cm x 15 cm
Limited warranty - 5 years
GFGT StarTech.com USB-C Multiport Adapter - SD - Power Delivery - 4K HDMI - GbE - 2x USB 3.0 In Stock £70.33
GFGT StarTech.com Thin Client Mount - VESA In Stock £23.04
GFGT StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
GFGT StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
GFGT StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
GFGT StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.52
