Our checkout area is closed for maintenance, but should be back online soon. We apologise for any inconvenience caused
StarTech.com Desk-Mount Dual-Monitor Arm
Quicklinx: F2HFWS00 Mfr#: ARMBARDUOG
Accessory Type: Mount
35 In Stock
£94.15 ex VAT
£112.98 inc VAT
This deskmount dual-monitor arm lets you mount two 13" to 27" VESA mount monitors, each weighing up to 17.6 lb. (8 kg), onto a single low-profile base. It gives you flexible desk-clamp or grommet-hole mounting, letting you save space while creating an ergonomic workspace in any office environment.
With a stable dual-arm design, the double-monitor mount lets you create more usable work space by mounting your monitors side by side on a single base. The screen mount features a flat low-profile back that lets you position your displays against a wall or cubicle wall.
The computer monitor desk mount features adjustable height along the pole. The smooth +/- 30° tilt motion and +/- 30° swivel make it easy to find the optimal viewing angle. You can also rotate your display 360° for portrait or landscape viewing, and make sure your displays are perfectly aligned using the micro-adjustment knob.
The dual-monitor arm is easy to install, with the desk-clamp or grommet mount (hardware included). Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
Adding two monitors gives you the extra screen space you need to simplify multitasking and maximize your productivity.
  • Versatile mounting options
    Choose to mount the Dual Monitor Mount using either a desk clamp or grommet-hole option to suit different desk configurations.
  • Comprehensive adjustments
    Easily adjust height, tilt, and swivel for a personalized workspace, accommodating various viewing angles and heights.
  • Suitable for multiple monitor sizes
    Supports a range of monitor sizes from 13" to 27", allowing users to find the perfect fit for their setup.
  • Sturdy construction
    Constructed from plastic, aluminum, and steel to provide reliable support for monitors weighing up to 8 kg each.
  • Organized workspace
    Features integrated cable management that helps keep cords organized and out of sight, enhancing workspace aesthetics.
StarTech.com Dual Monitor Mount - Supports Monitors 13" to 27" - Adjustable - Desk Clamp or Grommet-Hole Desk Mount for Dual VESA Monitors - Black (ARMBARDUOG) stand - for 2 monitors - black
Stand - grommet, desk-mountable
13.5 cm x 87 cm x 51.5 cm
Tilt
-30° to 30°
Rotation
360°
Swivel
-30° to 30°
Adjustments
Height, tilt, swivel, rotation
4.9 kg
Recommended Use
2 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, aluminium, steel
Package Content
2 x VESA monitor mounts, hex key, 5 x rubber pads, desk clamp, column, 2 x end caps, 2 x cable-management clips (column), 2 x monitor arms, 2 x cable-management clips (monitor arm), 2 x end cap screws, hex key screwdriver, 8 x M4x14 screws, 8 x M5x14 screws, 8 x flat washers, grommet mounting adapter, grommet mount plate
3-year warranty
13.5 cm
87 cm
51.5 cm
4.9 kg
Material
Package Content
AV Furniture
Stand
Recommended Use
2 monitors
Placing / Mounting
Grommet, desk-mountable
Cable Management
13"-27"
Tilt
-30° to 30°
Rotation
360°
Swivel
-30° to 30°
Adjustments
Max Load Weight
8 kg
Assembly Required
Dimensions & Weight Details
5 kg
Limited warranty - 3 years
F2HF StarTech.com Thin Client Mount - VESA In Stock £23.04
F2HF StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors In Stock £191.88
F2HF StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
F2HF StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
F2HF StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
F2HF StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.52
