This deskmount dual-monitor arm lets you mount two 13" to 27" VESA mount monitors, each weighing up to 17.6 lb. (8 kg), onto a single low-profile base. It gives you flexible desk-clamp or grommet-hole mounting, letting you save space while creating an ergonomic workspace in any office environment.
With a stable dual-arm design, the double-monitor mount lets you create more usable work space by mounting your monitors side by side on a single base. The screen mount features a flat low-profile back that lets you position your displays against a wall or cubicle wall.
The computer monitor desk mount features adjustable height along the pole. The smooth +/- 30° tilt motion and +/- 30° swivel make it easy to find the optimal viewing angle. You can also rotate your display 360° for portrait or landscape viewing, and make sure your displays are perfectly aligned using the micro-adjustment knob.
The dual-monitor arm is easy to install, with the desk-clamp or grommet mount (hardware included). Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
Adding two monitors gives you the extra screen space you need to simplify multitasking and maximize your productivity.
Versatile mounting options
Choose to mount the Dual Monitor Mount using either a desk clamp or grommet-hole option to suit different desk configurations. -
Comprehensive adjustments
Easily adjust height, tilt, and swivel for a personalized workspace, accommodating various viewing angles and heights. -
Suitable for multiple monitor sizes
Supports a range of monitor sizes from 13" to 27", allowing users to find the perfect fit for their setup. -
Sturdy construction
Constructed from plastic, aluminum, and steel to provide reliable support for monitors weighing up to 8 kg each. -
Organized workspace
Features integrated cable management that helps keep cords organized and out of sight, enhancing workspace aesthetics.
- StarTech.com Dual Monitor Mount - Supports Monitors 13" to 27" - Adjustable - Desk Clamp or Grommet-Hole Desk Mount for Dual VESA Monitors - Black (ARMBARDUOG) stand - for 2 monitors - black
- Product Type
- Stand - grommet, desk-mountable
- 13.5 cm x 87 cm x 51.5 cm
- Tilt
- -30° to 30°
- Rotation
- 360°
- Swivel
- -30° to 30°
- Adjustments
- Height, tilt, swivel, rotation
- 4.9 kg
- Recommended Use
- 2 monitors
- Recommended Display Size
- 13"-27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Plastic, aluminium, steel
- Black
- Package Content
- 2 x VESA monitor mounts, hex key, 5 x rubber pads, desk clamp, column, 2 x end caps, 2 x cable-management clips (column), 2 x monitor arms, 2 x cable-management clips (monitor arm), 2 x end cap screws, hex key screwdriver, 8 x M4x14 screws, 8 x M5x14 screws, 8 x flat washers, grommet mounting adapter, grommet mount plate
- 3-year warranty
- 13.5 cm
- 87 cm
- 51.5 cm
- 4.9 kg
- Material
- Black
- Package Content
AV Furniture
- Stand
- Recommended Use
- 2 monitors
- Placing / Mounting
- Grommet, desk-mountable
- Cable Management
- Integrated cable management
- 13"-27"
- Tilt
- -30° to 30°
- Rotation
- 360°
- Swivel
- -30° to 30°
- Adjustments
- Max Load Weight
- 8 kg
- Assembly Required
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 5 kg
- Limited warranty - 3 years
StarTech.com Thin Client Mount - VESA | In Stock | £22.53 |
StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors | In Stock | £191.88 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £53.32 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £59.75 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £77.01 |
StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop | In Stock | £7.52 |
