StarTech.com Desk-Mount Dual-Monitor Arm
Quicklinx: F2HFWS00 Mfr#: ARMBARDUOG
Accessory Type: Mount
More than 50 in stock
£71.68 ex VAT
£86.01 inc VAT
This deskmount dual-monitor arm lets you mount two 13" to 27" VESA mount monitors, each weighing up to 17.6 lb. (8 kg), onto a single low-profile base. It gives you flexible desk-clamp or grommet-hole mounting, letting you save space while creating an ergonomic workspace in any office environment.
With a stable dual-arm design, the double-monitor mount lets you create more usable work space by mounting your monitors side by side on a single base. The screen mount features a flat low-profile back that lets you position your displays against a wall or cubicle wall.
The computer monitor desk mount features adjustable height along the pole. The smooth +/- 30° tilt motion and +/- 30° swivel make it easy to find the optimal viewing angle. You can also rotate your display 360° for portrait or landscape viewing, and make sure your displays are perfectly aligned using the micro-adjustment knob.
The dual-monitor arm is easy to install, with the desk-clamp or grommet mount (hardware included). Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
Adding two monitors gives you the extra screen space you need to simplify multitasking and maximize your productivity.
StarTech.com Dual Monitor Mount - Supports Monitors 13" to 27" - Adjustable - Desk Clamp or Grommet-Hole Desk Mount for Dual VESA Monitors - Black (ARMBARDUOG) - stand
Stand - grommet, desk-mountable
13.5 cm x 87 cm x 51.5 cm
Tilt
-30° to 30°
Rotation
360°
Swivel
-30° to 30°
Adjustments
Height, tilt, swivel, rotation
Recommended Use
2 monitors
Recommended Display Size
13"-27"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, aluminium, steel
Package Content
2 x VESA monitor mounts, hex key, 5 x rubber pads, desk clamp, column, 2 x end caps, 2 x cable-management clips (column), 2 x monitor arms, 2 x cable-management clips (monitor arm), 2 x end cap screws, hex key screwdriver, 8 x M4x14 screws, 8 x M5x14 screws, 8 x flat washers, grommet mounting adapter, grommet mount plate
3-year warranty
13.5 cm
87 cm
51.5 cm
Material
Package Content
AV Furniture
Stand
Recommended Use
2 monitors
Placing / Mounting
Grommet, desk-mountable
Cable Management
13"-27"
Tilt
-30° to 30°
Rotation
360°
Swivel
-30° to 30°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
5 kg
Limited warranty - 3 years
StarTech.com Desk-Mount Dual-Monitor Arm Bundle deal on StarTech.com Desk-Mount Dual-Monitor Arm
£170.85
Price Range Ex VAT: 50 - 100
