Create an ergonomic workspace with this premium desk-mount dual monitor arm, for monitors up to 27" each. The two articulating monitor arms with dual-swivel action offer a wide range of motion side to side. The attractive silver finish enhances the aesthetics of your workspace.
The dual articulating monitor arms offer a wide range of motion on several axes. It provides effortless motion to adjust the position of your monitors.
The robust aluminum design provides stable support for your monitors. The computer-monitor desk mount supports two VESA mount monitors (75x75, 100x100) with a weight capacity of up to 22 lb. (10 kg) per display. The cable-management channel helps to keep your workstation neat and tidy.
Share your screen with ease. The double monitor mount offers a full +180-degree / -180-degree pan, to move your screen left or right. It tilts freely +90 / -15 degrees to adjust the angle up or down. Rotate your screens for landscape or portrait viewing.
Work in comfort. This height-adjustable monitor mount lets you raise or lower the monitor arms along the pole, with a range of up to 6.3" (160 mm).
The fully assembled desk clamp and pole, plus quick slide-and-click connections, ensure easy assembly. It also saves time when setting up multiple units. The dual-screen mount gives you the option of desk clamp or grommet hole mounting (hardware included).
Enjoy a Wide Range of Motion to Work in Comfort
The?dual articulating monitor arms?offer a wide range of motion on several axes. It provides effortless motion to adjust the position of your monitors. -
Sleek and Stable Aluminum Design
The robust aluminum design provides stable support for your monitors. The computer-monitor desk mount supports two VESA mount monitors (75x75, 100x100) with a weight capacity of up to 22 lb. (10 kg) per display. The cable-management channel helps to keep your workstation neat and tidy. -
Adjust your Viewing Angle
Share your screen with ease. The double monitor mount offers a full +180-degree / -180-degree pan, to move your screen left or right. It tilts freely +90 / -15 degrees to adjust the angle up or down. Rotate your screens for landscape or portrait viewing. -
Height Adjustment
Work in comfort. This height-adjustable monitor mount lets you raise or lower the monitor arms along the pole, with a range of up to 6.3" (160 mm) -
Tool-less Assembly
The fully assembled desk clamp and pole, plus quick slide-and-click connections,?ensure easy assembly. It also saves time when setting up multiple units. The dual-screen mount gives you the option of desk clamp or grommet hole mounting (hardware included). The TAA compliant?ARMDUALPS?is backed by a StarTech.com 10-year warranty and free lifetime technical support.
- StarTech.com Desk Mount Dual Monitor Arm, Premium Articulating Monitor Arm, up to 27" VESA Mount Displays, Height Adjustable Monitor Mount, Rotating/Swivel/Tilt, Desk Clamp/Grommet, Silver - Easy & Quick Assembly (ARMDUALPS) mounting kit - adjustable arm - for 2 LCD displays - silver - TAA Compliant
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- 19 cm x 22 cm x 52 cm
- Tilt
- -15° to 90°
- Pan
- -180° to 180°
- Rotation
- 360°
- Adjustments
- Height, pan, tilt, rotation
- 5.7 kg
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- 13"-27"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 10 kg
- Material
- Aluminium
- Silver
- TAA Compliant
- Package Content
- 2 x VESA monitor mounts, desk clamp, EVA cushion, cable management clip, thumbscrews, 4 x swivel arms, shoulder, pole assembly, 2 x M3 hex keys
- 5-year warranty
- 19 cm
- 22 cm
- 52 cm
- 5.7 kg
- Material
- Aluminium
- Silver
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- 2 LCD displays
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- 13"-27"
- Tilt
- -15° to 90°
- Pan
- -180° to 180°
- Rotation
- 360°
- Adjustments
- Max Load Weight
- 10 kg
- TAA Compliant
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 14.5 cm x 33 cm x 46.5 cm / 5.8 kg
- Limited warranty - 5 years
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.67 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £176.82 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £226.92 |
StarTech.com Vertical Dual Monitor Mount | In Stock | £76.91 |
StarTech.com Thin Client Mount - VESA | In Stock | £26.04 |
StarTech.com Desk-Mount Dual-Monitor Arm | In Stock | £104.29 |
StarTech.com Desk Mount Dual Monitor Arm - Crossbar | In Stock | £100.55 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £51.65 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £58.93 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £75.94 |
