Create a sleek and elegant two-monitor set-up while saving space. This stylish desk mount dual monitor arm brings you a cost-effective and versatile solution to an ergonomic workspace. Enjoy a wide range of motion with the dual swivel arms plus tilt, pan, rotation and height adjustment.
The multi monitor mount gives you the flexibility to set-up your desktop your way. Each of the articulating arms extends a full 15.2" (38.6 cm) to adjust to your needs.
The flexible dual-swivel arms make it easy to position your monitors. You can place your monitors to face you, or even turn your monitors right around, 180-degrees, to share your screen with others.
The attractive dual monitor mount utilizes a contoured design made of durable aluminum, with an attractive high gloss black finish. The two-monitor arm securely supports two VESA mount (75x75, 100x100) monitors up to 32", with a weight capacity of 17.6 lb. (8 kg) per monitor.
The double monitor arm lets you smoothly and effortlessly adjust the position of your screens for optimum viewing. Tilt your monitors +30/-30 degrees. Swivel +90/-90 degrees to the left or right. Rotate your monitors to portrait or landscape position with the 360-degree rotary VESA plate.
Adjust your monitors to the desired height. The dual screen mount is height adjustable along the 15.7" (39.8 cm) pole.
The multi monitor mount is easy to install, using the C-clamp to attach the mount to the edge of your desk, table, or counter. A keyhole design on the VESA mount makes it easy to slide your monitor onto the mount, then tighten into place. Built-in cable management helps to keep your cables neatly tucked away.
Versatile Adjustable Arm
The adjustable arm design allows for a range of motion, enabling monitors to tilt from -30° to 30° and rotate from -180° to 180°, accommodating various viewing preferences. -
Durable Aluminum Construction
Crafted from aluminum, this mount provides a robust yet lightweight solution that supports monitors with a maximum load weight of 8 kg, ensuring stability and longevity. -
Integrated Cable Management
Designed with integrated cable management, this mount effectively organizes cables for a tidy workspace, minimizing distractions and providing a clean, streamlined look. -
Height and Swivel Adjustments
The ability to adjust height and swivel up to 90° on each arm ensures that monitors can be positioned for maximum comfort and productivity, promoting better ergonomics.
- StarTech.com Desk Mount Dual Monitor Arm, Desk Clamp VESA Compatible Monitor Mount for up to 32 inch Displays, Ergonomic Articulating Monitor Arm, Height Adjustable/Tilt/Swivel/Rotating - Double Monitor Arm (ARMDUAL3) mounting kit - adjustable arm - for 2 monitors - black
- Product Type
- Mounting kit (adjustable arm) - desk-mountable
- 86.6 cm x 12.4 cm x 49.8 cm
- Tilt
- -30° to 30°
- Rotation
- -180° to 180°
- Swivel
- -90° to 90°
- Adjustments
- Height, tilt, swivel, rotation
- Joints Qty
- 2
- 4.16 kg
- Recommended Use
- 2 monitors
- Recommended Display Size
- Up to 32"
- VESA Mounting Interface
- 100 x 100 mm, 75 x 75 mm
- Max Load Weight
- 8 kg
- Material
- Aluminium
- Black
- Package Content
- 8 x M4x12 screws, hex key (4mm), 8 x washers, column, hex key (6mm), cable management clip, 8 x M5x12 screws, swivel arm, 2 x desk clamp screws, 2 x pole assembly screws
- 5-year warranty
- 86.6 cm
- 12.4 cm
- 49.8 cm
- 4.16 kg
- Material
- Aluminium
- Black
- Package Content
AV Furniture
- Mounting kit
- Design
- Adjustable arm
- Recommended Use
- 2 monitors
- Placing / Mounting
- Desk-mountable
- Cable Management
- Integrated cable management
- Up to 32"
- Tilt
- -30° to 30°
- Rotation
- -180° to 180°
- Swivel
- -90° to 90°
- Adjustments
- Joints Qty
- 2
- Max Load Weight
- 8 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 44.5 cm x 20.5 cm x 15.6 cm / 4.36 kg
- Limited warranty - 5 years
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £141.07 |
StarTech.com Monitor Mount - USB Passthrough | In Stock | £167.20 |
StarTech.com Dual Monitor Mount - Stackable | In Stock | £221.12 |
StarTech.com Vertical Dual Monitor Mount | In Stock | £71.38 |
StarTech.com Thin Client Mount - VESA | In Stock | £23.55 |
StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors | In Stock | £198.27 |
StarTech.com Desk Mount Dual Monitor Arm - Crossbar | In Stock | £101.74 |
StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy | In Stock | £52.08 |
StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £59.62 |
StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy | In Stock | £76.85 |
