StarTech.com Desk Mount Dual Monitor Arm - Crossbar
Quicklinx: FKDKWS00 Mfr#: ARMDUAL2
Accessory Type: Mount
More than 50 In Stock
£98.86 ex VAT
£118.63 inc VAT
Work in comfort while saving space. This highly functional desk mount dual monitor arm brings you a cost-effective and versatile solution to an ergonomic workspace. Enjoy a wide range of motion with the double-jointed crossbar design plus tilt, swivel, rotation and height adjustment.
The multi monitor mount gives you the flexibility to set-up your desktop your way. Each of the articulating arms extends a full 15.7" (39.9 cm) to adjust to your needs.
The flexible double joints on the arms give you numerous options to position your monitors. You can place your monitors to face you, or even turn your monitors right around, 180-degrees, to share your screen with others. If you choose, you can also tighten the joints, making your setup as stationary as you like.
The cross-bar design provides a clean and simple look, while keeping monitors aligned. Use the micro-adjustment knob to align your monitors perfectly.
Made of steel, the rugged two display arm securely supports two VESA mount (75x75, 100x100) monitors up to 32", with a weight capacity of 17.6 lb. (8 kg) per monitor.
The double monitor arm lets you smoothly and effortlessly adjust the position of your screens for optimum viewing. Tilt your monitors +45/-45 degrees. Swivel +90/-90 degrees to the left or right. Rotate your monitors to portrait or landscape position with the 360-degree rotary VESA plate.
Adjust your monitors to the desired height. The dual screen mount is height adjustable along the 17.4" (44.3 cm) pole.
The multiple monitor mount is easy to install, using the C-clamp to attach the mount to the edge of your desk, table, or counter or mounting it through a grommet hole. The detachable VESA plate makes it easy to attach or remove your monitor. The? built-in cable management keeps your cables neatly tucked away.
  • Adjustable Design
    The adjustable arm design allows for personalized configuration, making it easy to achieve an ergonomic workspace that suits individual needs.
  • Premium Materials
    Made from steel, this dual monitor arm is built to withstand the test of time while providing sturdy support for monitors.
  • Support for Dual Monitors
    Recommended for two monitors, enhancing productivity by allowing users to multitask efficiently and utilize screen space effectively.
  • Versatile Adjustments
    Features a range of adjustments, including height, tilt from -45° to 45°, and swivel from -90° to 90°, ensuring optimal viewing angles and comfort.
  • Efficient Cable Management
    Integrated cable management clips help to organize cables neatly, preventing tangling and keeping the workspace tidy.
StarTech.com Desk Mount Dual Monitor Arm, Desk Clamp / Grommet VESA Monitor Mount for up to 32 inch Displays, Ergonomic Articulating Monitor Arm, Height Adjustable/Tilt/Swivel/Rotating - Space-saving Design (ARMDUAL2) mounting kit - adjustable arm - for 2 monitors - black
Mounting kit (adjustable arm) - desk-mountable
91.3 cm x 14.8 cm x 54.8 cm
Tilt
-45° to 45°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
Height, tilt, swivel, rotation
4.6 kg
Recommended Use
2 monitors
Recommended Display Size
13"-32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Steel
Package Content
Pole, pole cap, 8 x M4x12 screws, hex key (4mm), hex key (3mm), 5 x rubber pads, desk clamp, grommet plate, 8 x washers, hex key (6mm), 16 x spacers, 3 x pole screws, 2 x cable-management clips, 8 x M5x12 screws, 8 x M4x16 screws, 8 x M5x16 screws, grommet base plate, swivel arm, 2 x micro adjustment knobs, 2 x micro adjustment knob screws, 4 x swivel arm cable clips
5-year warranty
91.3 cm
14.8 cm
54.8 cm
4.6 kg
Material
Steel
Package Content
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Desk-mountable
Cable Management
13"-32"
Tilt
-45° to 45°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
44.8 cm x 22.5 cm x 13.5 cm / 4.8 kg
Limited warranty - 5 years
FKDK StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £139.14
FKDK StarTech.com Monitor Mount - USB Passthrough In Stock £161.64
FKDK StarTech.com Dual Monitor Mount - Stackable In Stock £217.58
FKDK StarTech.com Vertical Dual Monitor Mount In Stock £68.85
FKDK StarTech.com Thin Client Mount - VESA In Stock £23.04
FKDK StarTech.com Desk Mount Dual Monitor Arm -Articulating-Up to 27" Monitors In Stock £191.88
FKDK StarTech.com Desk Mount Dual Monitor Arm - Dual Swivel Articulating In Stock £97.96
FKDK StarTech.com 21.5in. Monitor Privacy Screen - Universal - Matte/Glossy In Stock £54.54
FKDK StarTech.com 24in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £61.12
FKDK StarTech.com 27in. Monitor Privacy Screen - Universal - Matte / Glossy In Stock £77.54
FKDK StarTech.com Dual Desk Mount Monitor Arm - Built-in 2-port USB and 3.5 mm In Stock £191.34
FKDK StarTech.com Slim Anti-Theft K-Slot Lock Plate Adapter for MacBook/Tablet/iPad/Phone/Laptop In Stock £7.52
