StarTech.com Dell EMC SFP-1G-SX Compatible SFP MM Module
Quicklinx: FHLMWS00 Mfr#: SFP1GSXEMCST
Type: Transceiver
£23.91 ex VAT
£28.69 inc VAT
The SFP1GSXEMCST is a Dell EMC SFP-1G-SX compatible fiber transceiver module that has been designed, programmed and tested to work with Dell EMC brand switches and routers. It delivers dependable 1 GbE connectivity over fiber cable, for 1000Base-SX compliant networks, with a maximum distance of up to 500 m (1640 ft)).
This SFP fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Dell EMC SFP-1G-SX Compatible SFP Module, 1000BASE-SX, 1GbE Multimode Fiber MMF Optic Transceiver, 1GE Gigabit Ethernet SFP, LC Connector, 550m, 850nm, DDM, Mini GBIC Module - Lifetime Warranty (SFP1GSXEMCST) - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - LC multi-mode
Plug-in module
Cabling Type
1000Base-SX
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
1GbE
Max Transfer Distance
550 m
Dell EMC SFP-1G-SX
5.84 cm x 1.39 cm x 1.26 cm
30 g
Plug-in module
Wired
Cabling Type
1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
Optical Wave Length
850 nm
550 m
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 1000Base-SX - LC multi-mode female x 2
MTBF
53,972,659 hours
FCC, RoHS, REACH, MSA
Dell EMC SFP-1G-SX
5.84 cm
1.39 cm
1.26 cm
30 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
Type: Transceiver
