StarTech.com Dell EMC SFP-10G-ZR Compatible SFP+ SM Module
Quicklinx: FHLDWS00 Mfr#: SFP10GZREMST
The SFP10GZREMST is a Dell EMC SFP-10G-ZR compatible fiber transceiver module that has been designed, programmed and tested to work with Dell EMC brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-ZR compliant networks, with a maximum distance of up to 80 km (49.7 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Dell EMC SFP-10G-ZR Compatible SFP+ Module, 10GBASE-ZR, 10GbE Single Mode (SMF) Fiber SMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 80km, 1550nm, DDM, 10Gb SFP+ - Lifetime Warranty (SFP10GZREMST) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
10GBase-ZR
Data Transfer Rate
10 Gbps
Optical Wave Length
1550 nm
10GbE
Max Transfer Distance
80 km
Dell EMC SFP-10G-ZR
5.84 cm x 1.39 cm x 1.26 cm
30 g
Plug-in module
Wired
Cabling Type
10GBase-ZR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
1550 nm
80 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-ZR - LC single-mode female x 2
MTBF
38,631,862 hours
UL, FCC, MSA
Dell EMC SFP-10G-ZR
1 Watt
5.84 cm
1.39 cm
1.26 cm
30 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
