StarTech.com Dell EMC SFP-10G-USR Compatible SFP+ MM Module
Quicklinx: FHL6WS00 Mfr#: SFP10GUSREMS
£97.76 ex VAT
£117.31 inc VAT
The SFP10GUSREMS is a Dell EMC SFP-10G-USR compatible fiber transceiver module that has been designed, programmed and tested to work with Dell EMC brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10Gbase-SR compliant networks, with a maximum distance of up to 150 m (492 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Dell EMC SFP-10G-USR Compatible SFP+ Module, 10GBASE-SR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 150m, 850nm, DDM, 10Gbps SFP+ - Lifetime Warranty (SFP10GUSREMS) - SFP+ transceiver module - 10GbE
SFP+ transceiver module - LC multi-mode
Plug-in module
Cabling Type
10GBase-SR
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
10GbE
Max Transfer Distance
150 m
5.84 cm x 1.39 cm x 1.26 cm
30 g
Plug-in module
Wired
Cabling Type
10GBase-SR
10GbE
Data Transfer Rate
10 Gbps
Optical Wave Length
850 nm
150 m
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 10GBase-SR - LC multi-mode female x 2
MTBF
53,972,659 hours
UL, FCC, MSA
1 Watt
5.84 cm
1.39 cm
1.26 cm
30 g
Shipping Width
9 cm
Shipping Depth
11.5 cm
Shipping Height
3.1 cm
Shipping Weight
50 g
Limited warranty - lifetime
