The SFP10GUSREMS is a Dell EMC SFP-10G-USR compatible fiber transceiver module that has been designed, programmed and tested to work with Dell EMC brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10Gbase-SR compliant networks, with a maximum distance of up to 150 m (492 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
- StarTech.com Dell EMC SFP-10G-USR Compatible SFP+ Module, 10GBASE-SR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 150m, 850nm, DDM, 10Gbps SFP+ - Lifetime Warranty (SFP10GUSREMS) - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 150 m
- OEM Manufacturer Equivalent Part Number
- Dell EMC SFP-10G-USR
- 5.84 cm x 1.39 cm x 1.26 cm
- 30 g
- Limited lifetime warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10GbE
- 10 Gbps
- 850 nm
- 150 m
- Full duplex mode, Digital Diagnostics Monitoring (DDM)
- 1 x Ethernet 10GBase-SR - LC multi-mode female x 2
- MTBF
- 53,972,659 hours
- UL, FCC, MSA
- 1 Watt
- 5.84 cm
- 1.39 cm
- 1.26 cm
- 30 g
- Shipping Width
- 9 cm
- Shipping Depth
- 11.5 cm
- Shipping Height
- 3.1 cm
- Shipping Weight
- 50 g
- Limited warranty - lifetime
