StarTech.com Dell EMC QSFP-40G-ESR4 Comp QSFP+ MM Module
Quicklinx: FHK6WS00 Mfr#: QSFP40GESR4E
£32.46 ex VAT
£38.95 inc VAT
The QSFP40GESR4E is a Dell EMC QSFP-40G-ESR4 compatible fiber transceiver module that has been designed, programmed and tested to work with Dell EMC brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 400 m (1312 ft.).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Dell EMC QSFP-40G-ESR4 Compatible QSFP+ Module, 40GBASE-SR4, 40GbE Multimode Fiber MMF Optic Transceiver, 40GE Gigabit Ethernet QSFP+, MPO Connector, 400m, 850nm, DDM, 40Gbps - Lifetime Warranty (QSFP40GESR4E) - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - MPO multi-mode
Plug-in module
Cabling Type
40GBASE-SR4
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
40GbE
Max Transfer Distance
400 m
5.84 cm x 1.39 cm x 1.26 cm
40 g
Plug-in module
Wired
Cabling Type
40GBASE-SR4
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
850 nm
400 m
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 40GBASE-SR4 - MPO multi-mode female
MTBF
45,017,120 hours
UL, FCC, RoHS, REACH, MSA
5.84 cm
1.39 cm
1.26 cm
40 g
Shipping Width
12 cm
Shipping Depth
20.5 cm
Shipping Height
35 cm
Shipping Weight
60 g
Limited warranty - lifetime
