StarTech.com Dell EMC QSFP-40G-ER4 Comp QSFP+ SM Module - 40GBase-ER4Q
Quicklinx: FJN6WS00 Mfr#: QSFP40GER4ES
£2,041.21 ex VAT
£2,449.45 inc VAT
The QSFP40GER4ES is a Cisco QSFP-40G-SR4-S compatible fiber transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 40 GbE connectivity over fiber cable, for 40GBase-SR4 compliant networks, with a maximum distance of up to 40 km (24.8 mi).
This QSFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
StarTech.com Dell EMC 3CSFP91 Compatible QSFP+ Module, 40GBASE-ER4, Single Mode (SMF) Fiber, 40GE Gigabit Ethernet QSFP+, LC 40 km, 1270nm to 1330nm, DDM, 40GbE QSFP+ Active Optical Cable - Lifetime Warranty (QSFP40GER4ES) - QSFP+ transceiver module - 40GbE
QSFP+ transceiver module - LC single-mode
Plug-in module
Cabling Type
40GBase-ER4Q
Data Transfer Rate
40 Gbps
Optical Wave Length
1311 nm
40GbE
Max Transfer Distance
40 km
5.84 cm x 1.39 cm x 1.26 cm
40 g
Plug-in module
Wired
Cabling Type
40GBase-ER4Q
40GbE
Data Transfer Rate
40 Gbps
Optical Wave Length
1311 nm
40 km
Full duplex mode, Digital Diagnostics Monitoring (DDM)
1 x Ethernet 40GBase-ER4Q - LC single-mode female x 2
MTBF
8,596,956 hours
UL, FCC, RoHS, REACH, MSA
1.6 Watt
5.84 cm
1.39 cm
1.26 cm
40 g
Shipping Width
12 cm
Shipping Depth
20.5 cm
Shipping Height
35 cm
Shipping Weight
60 g
Limited warranty - lifetime
Price Range Ex VAT: £1500+
