StarTech.com Dell EMC DAC Twinax Cable - DAC-SFP-10G-3M Com 3 m
Quicklinx: FJMMWS00 Mfr#: DACSFP10G3M
Length: 3m
Colour: Black
£31.59 ex VAT
£37.90 inc VAT
The DACSFP10G3M is a Dell EMC DAC-SFP-10G-3M compatible direct-attach copper SFP+ cable that's designed, programmed and tested to work with Dell EMC brand compatible switches and routers and complies with MSA industry standards. This passive Twinax copper cable supports 10 Gigabit Ethernet applications connected through SFP+ (Mini-GBIC) ports. This copper SFP+ cable is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions. Designed for high-speed performance, this low-power, low-latency 10GbE cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com offers a wide variety of direct-attach SFP cables and SFP modules, providing the convenience and reliability you need to ensure dependable network performance.
  • Reliable performance
    The 10GBase direct attach cable ensures high-speed connectivity between devices, suitable for data-intensive applications.
  • Efficient design
    With its twinaxial construction, this cable minimizes signal attenuation, ensuring clear data transmission over medium distances.
  • Secure connections
    The latched SFP+ connector design provides a firm lock, reducing the risk of accidental disconnections during operation.
  • Wide operating range
    This cable functions effectively in temperatures ranging from 0°C to 70°C, making it versatile for different environments.
  • Compliant with standards
    This cable adheres to important standards such as FCC, RoHS, REACH, and MSA, ensuring quality and safety for users.
StarTech.com Dell EMC DAC-SFP-10G-3M Compatible 3m 10G SFP+ to SFP+ Direct Attach Cable Twinax, 10GbE SFP+ Copper DAC 10 Gbps Low Power Passive Mini GBIC/Transceiver Module DAC, SFP Plus - Lifetime Warranty (DACSFP10G3M) - 10GBase direct attach cable - 3 m
Twinaxial
Passive cable
Length
3 m
Connector
SFP+ - plug - latched
Connector (Second End)
Network Cable Type
Twinaxial
Impedance
100 Ohm
Passive cable
Length
3 m
Connector
FCC, RoHS, REACH, MSA
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
4 cm
70 °C
Length: 3m
Colour: Black
